Adam can you give us the breakdown of spots? Maybe if SAU VIC don't take up spots we can poach them.
Next time we need more seeing there's a resurgence of trackwhoring... I mean the trackday is 3 months away and it's already sold out!
SAU NSW - 15
SAU VIC - ??
RENEW - ??
But yeah I'm glad I made the list... :P
  • Replies 640
Posted Images
SAU NSW - 15
SAU VIC - ??
RENEW - ??
But yeah I'm glad I made the list... :(
SAU NSW - 15
SAU VIC - 0
RENEW - 30
who knows - 15
We cant give any more spots until our Supp Regs are approved by CAMS and we know how many in total are available.
If you all paid and then got told you cant come you would all have the shits, so just hang tight there is plenty of time and as soon as we get approval we can let Adam know how many positions are available.
Thanks Nathan (I assume that's you :()
Fatz the reason why we team up with RENEW is because in the past we have had trouble getting the numbers but there has been a recent resurgence in the popularity of track days.
Rest assured we are not sitting idle behind the scenes.
SAUVIC are getting 0 spots :(
We'll come up in Nov for something else instead.
snowman, I say try and tee up an Oran park GP circuit day, with an Eastern creek day within a few days of each other. I'll be in it for sure to show you the fast way 'round... hahaha
All,
Im chatting with Aaron McGill to do a Mid Aug $200 day at OP GP. Hopefully a new post will be up soon.
Thanks
I was just going to suggest this :O
Maybe if we get that timing sorted out before hand, this could be its first use?
As Nathan pointed out, as soon as we get our supp regs approved by cams we will have a final number of entries we can take.
im sure there will be more spots made available, so dont write it off just yet and watch this space :P
i only got a few laps at wakefield (due to breaking my car) so im so keen for this!!
Andrew
Edited by RXB05S
WOW... not even a week after the last Track day and the next is sold out?
If i could be placed on the reserve list please Adam thad would be awsome.....
As im keen as!
Regards
Dave
For anyone needing tyres I was just at Gordon Levin Tyres (Emu Plains) and they are selling 235/45/17 A048 semi-slicks for $80/each 2nd hand (still plenty of meat). They were low on stock when I was there but said they get them often from weekend circuit meetings. That's a tidy price compared to the ~$400/each new.
thanks for that info.... i'll be giving them a call
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
