Sau Nsw 3rd Official Track Day For 2006
Abo Bob
  • Replies 640
Posted Images
I've got to pull out of this one aswell.
Will sell my spot if I can, not bothered about losing my deposit, we all know how these things work!
Liz.
Ok everyone. Time to ramp this track day up.
Let's get second payments from those that have deposited and lets see if we can get another 10 spots filled in the next few weeks.
If you are coming or thinking about it, let us know. If you've got a lame excuse then tell us so we can ridicule you into coming. Come on guys, this is the official SAU track day. Proper timing, all your Skyline friends should be there.
Also need a few more flag marshalls. Please put your hand up for that if you haven't already.
im still a maybe, however im going to apply for my LS2 license today. whens the last day to pay?
**edit** it says on CAMS website to apply through the club for 30 day temp license?. can anyone point me in the right direction?
Thank you Stan, James, Paul, Liz.
Last day to pay is just before all the spots sell out and you will know that you've missed it if it gets cancelled due to lack of interest.
To be honest there is a slight chance of it being called off due to lack of interest but I'm sure there are a few people out there who intend to come but haven't paid up yet. If that's you, get some money in now to secure the day.
I'm not saying it's definitely going to happen but just that it's a current talking point.
Abo Bob
Primordial
steve_gts4
nath95
yogi000
tuitahi
godzl1975
Oz GTR02V
satanic
Smoky
R33deviat
lingeringsoul
Oz GTR02V
boosted zed
Oz GTR02V - Steve Bowman
Oz GTR02V - Shane
Majanal
Have all paid something.
r33freely
hanyou
Have said they are coming - or something similar - but not paid anything.
I have Alan - Oz down as coming but no money.
Umm yeah I think it is Ralph sorry.
Refunds or holding of deposits for the next track day will only happen if the day gets cancelled or if it goes ahead and someone takes your spot. If you paid and can't go and we can't find someone to take your spot and the day goes on we can't refund the money sorry.
    • Hurry while stocks last! 🤣 13% points redemption on this $6000 Mont Blanc "James Dean" ballpoint pen at Yodobashi Camera in Umeda, Osaka
    • It's not that at all....I just love the R chassis too much to keep racing it! Absolutely impossible to fix the damn thing if I bend it.... That last off I had (when I neglected to do what Kel said), we removed a gum tree with the side of the boot....needed a new rear quarter, boot lid, floor straighten, rear bar, front bar, both front guards, radiator, bov return and I still haven't got it back for a proper alignment to check it is actually straight again). There are just too many ways in tarmac rally to do significant damage to a car that you can't really get parts for.
    • Now I'd said earlier I'd checked the fuses, and per @Stick180's suggestion I checked them all again. The check was to use the multimeter in continuity mode on the top of each fuse where the little metal tabs are available for that purpose. All good....except that very "A/T Control" fuse was actually blown when I pulled it out and looked at it. Put it back in, tested it again, there is continuity to both sides even though the fuse is blown. I'll need someone smarter than me, but my suspicion is that I was getting a circuit through a power supply, through an incandescent globe somewhere, to earth, to the shorted wire and back to the other side of the fuse, making it look like the fuse was OK when it wasn't....please anyone that understands this f**kery explain it to me. Bottom line....that suspicious purple/white wire, in an undamaged factory loom, that goes to the the wrong place in the fuse box has a dead short to earth, confirmed from both ends.  How a single wire in a factory loom can be shorted, especially the best protected loom in the whole car (underneath the top of the dash) is going to keep me awake at night because surely whatever caused the damage has (or will) damaged other wires in that loom too. So, to finish this long and sad story....cut the purple/white wire where it exits the fuse box, ran a new wire from there to the ECU loom pin 31, fired it up and drove happily into the sunset. Only 4 days of head scratching and peering into footwells to get me there. Another collection of wire removed (in addition to the earlier photo) and a bunch of 10a fuses that gave their lives for the trouble shooting....thank you for their service.  And, since the car was in the shed I resealed the cam cover (first time I've ever had a new seal leak on an RB, but the Stagea is that kind of lucky), and I put in the boost doc cam splash plates to try and turn down the blow by a bit while I was there. Which, was all good because it also let me find the slow coolant leak, turns out it was from the turbo water supply which I nipped up again (the banjo bolt got new washers, and I tightened the hose end and hose to banjo fitting while I was there)
    • So, as it turns out, a new wire was the answer I went for, but getting there was not straightforward... Firstly, I'd been told before by shops that had worked on the car that it had some weird factory wiring, and I can now confirm that is true in at least a couple of places. For example....that very purple/white wire that provides IGN power to ECU pin 31.....I traced it out of the ECU loom into a connector high on the nav's A pillar under the dash, where it headed up and out of site across the dash, then back down at driver's A pillar. After trying about 8 different relays I found it coming into the back of the fuse box, and confirmed it was the same wire with a multimeter* (more to follow on that.... So, which fuse is the ECU IGN power connected to in my car?  Very top right, labelled IGN (good), 10A (good), Auto Trans Control (WTF?). It's not impossible it has been f**ked with before, but if so someone removed the pins from the back of the fuse box and moved it somewhere else, noting an AT control fuse would be functionally useless as the car was auto converted to manual long ago. It is not simply a wire cut and joined to the wrong place, both ends of the wire are the same colour just one is in the wrong location (you can see there is an IGN Engine Control fuse in the bottom row 4th from the right. Note, that is the fuse box sticker from my actual car, so either I have the wrong coin holder sticker, someone f**ked with it post factory, or factory sticker does not match the wiring.....whichever option it is just plain weird. Undermining the likelihood of someone having gone to that trouble to move a power feed when everything else in the loom had already been butchered....the fuse next to it IGN 7.5a ABS doesn't even have a wire running to it....so no idea where that fuse is on this car. All strange. But not the problem with my ECU power.
    • New tank clean paint and install complete 🤙
