  • Replies 640
Posted Images
well.. when i signed up for this day, i thought there was no way my car wouldnt be back together...
but as the day is approaching fast, it looks like im a pretty slim chance to fill my driving spot on the day :P
enjoy everyone.
Oh :D
Still a fair way off?
Yeah fair call
Do you have the N1 water pump? If so, check around it for leaks :P
There was one on mine but its all fixed now - its a common thing
nah.. i had "the hole" welded up.. its not the water pump. its under the plenum somewhere. i think im just gonna drink a whole lot of beer then worry about it when im sober again.
hahahaha
good plan, ill help you out if you want a hand :P
Yeah that hole is a pest, but yeah its a shame it isnt that, thats an easy fix
Oz, maybe last session. Play it by ear. Apparently RENEW spectated a day with many more cars than we have entered and I'm told "you could have fired a cannon down the straight late in the day and hit no one". I said it would never happen while the love boat, the madman in his GTR and me were there. Let's just see what happens.
As I said, Im will to give it a go, but some free lap time to play would be gold, even a couple of 15 min sessions throughout the day would be nice. Anyway only 2 sleeps to go!
I don't think there will be any passenger riding. In other news though, there will be a familiarisation session at the start of the day. Newbies will go out in their own cars with an instructor (me or Oz or one of the more experienced people) for a few 120 km/h laps.
Also I just got this email and attachements.
Dear entrants,
Following is a list of entrants for this Sunday’s supersprint, along with competitor numbers and groups.
1 Brad Trenwith Red
2 Nathan Stiffle
6 Neil Trenwith Red
16 Renny Roden Blue
20 Daniel Bennett Green
21 Anthony Donnell Green
23 Gavin Bellamy Yellow
24 Andrew Burley Red
26 Shane Young Green
27 Mike Dempsey Red
29 Laurie Packer Red
38 David Nguyen White
42 Andrew Bollom Green
48 Paul Kalie Green
53 Kevin Quirk
54 Chris Kinsella Yellow
55 Caine de Fonseca Blue
57 Shane Stiffle Yellow
60 Matthew Currie Yellow
63 Aaron Owers Blue
61 Adam Finch White
68 Robert Talevski Red
72 Matthew Finch Blue
76 Matthew Reid
77 Tim Stephinson
83 Darren Mews Red
94 Joel Fitzgerald Green
95 Adam West Blue
96 Alan Cummine Green
97 Patrick Garvan Green
98 Rod Pobestek White
99 Sean Buchanan Red
101 Jon Bates Green
102 Paul Lewis Red
103 Nicholas Smyrhios Yellow
104 Stanley Choi Yellow
105 Adam Parsons Green
106 Ian Anderson Green
107 Adam Baldwin Red
108 Raymond Dean
109 Ralph Louwdyk
110 Shaun Malkic
111 Steve Reddel
112 Andrew Tuitahi Yellow
113 Aaron Li Yellow
114 Anthony Reed Red
115 George Rokkas Yellow
122 Wilbur Palijo
696 Greg Boyle Red
Please note your number, and have them on your car, as per the Supplementary Regulations when you attend scrutineering. Please also note your group. If you do not see a group next to your name, it is because you have not submitted your entry form yet. Please try to do so, before Sunday.
Attached is a bulletin amending the Supplementary Regulations to now include a familiarisation session for first time drivers. This session will be the first on track session.
Entrants are reminded of the schedule for the day, as per the Supplementary Regulations.
Pre-event scrutineering: 7.15am-8.45am
Driver’s Briefing: 9.00am
Event Schedule: 9.30am-5.00pm
Entrants are asked to get to the track at 7.00am or as close to as possible, so that the pre-event formalities can go smoothly and be completed on time.
As soon as possible after arriving at the track, entrants are asked to attend the Event Secretary’s office (located in the base of the control tower) to sign in. Please have your CAMS licence and club membership card with you. You should be able to collect your timing transponder at this time. You will also be given a scrutineering sheet. Please then proceed with it, and your car, to the scrutineering shed.
Attached is a scrutineering guide and a driver’s briefing guide. Please read them so you can be informed.
For those unfamiliar with Eastern Creek, attached is a small sketch showing the layout and important locations.
See you on the day,
Craig Hamilton – Event Secretary.
Bulletin_1.pdf
Driver_Briefing.doc
EC_Venue_Map.pdf
Scrutineering.doc
Trust them to put an Asian in the Yellow group :P
Adam, what's the order of the groups? I don't want to be thrown into a group where I can't keep up :D *only 2nd time on a track*
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
