  • Replies 640
Posted Images
Yeah wilch and I were laughing about that one... I went with a GTT and left with a GTR - WOOOHOOOO!!!!
wilch clocked a 2:04 without a car! Imagine what he'd be like with a car :/
The RX7 had a split fuel line. The reason the guys couldn't put the fire out probably is because the lines were on fire from front to back of the car.
I've been over to the RENEW website and they have been effusive with their thanks for the flaggies efforts. We all really appreciate you guys.
Here is the combined times. I slipped down to 13th in the end from 10th earlier.
Reedy snuck into the 1:53's, OZ close to 1:51 flat, the love boat stormed around in 1:44, Majanal did a 1:54 before his intercooler hose blew apart, he and Chris Easton showed what the RB30DET's are capable of. Both had low peak power and crappy tyres but put in some really good times. Good to see Ando in the sub 2 minute club too.
Check my new sig :/
Here is the rest of the times.
Thanks to Abo Bob and the Renew guys for organising the day. I had a great day.
The only thing that I didn't like was the fact that some of us n00bs to EC, that have only done one track day somewhere else previously, weren't allowed to go out in the morning with an experienced driver to learn the lines and the track.
I went out freaking scared after the first few long corners. My car felt like it was all over the place, that and I had someone right up my arse (who I let pass asap). I was seriously shaken up. My car felt so unstable in the first session. It really freaked me out, especially since there just seem to be walls everywhere.
Because of this I skipped my second session.
Anyway, after playing with the suspension and tyre pressures I went back out and had a ball despite the fact I that there are two corners which are after a couple of crests, one goes right and one goes left. I was pretty much guessing which was which.. Which is really bad. But hey, I guess that's what happens when you're put out there for your first time and are expected to be up to pace with everyone else.....
Regardless, I had a ball. So much fun. Soooo much fun. Sorry I didn't open her up and get her sideways near the guys at turn two. I didn't want to burn the tires this time around, I have no more monies for new ones after that Oran day!
Fear my massive legs!
and grrr to spelling my last name wrong. lol
Abo,
It was good to see your fastest lap of the day was actually the last one when we were dualing! Good work!
Yeah, interesting. I really need to get some in car footage the next time I am tailing you around a track. It's a surreal look as you are slipping around the place pushing a bit hard then regaining control within a single second because we are both doing between 100 and 200+ km/h and often within a 1-2 car lengths of each other as it's happening.
Adam/Paul Good to see you two battling it out was good to watch. Same with the two rx7's (car 1 and other one).
Saw Majanal wanting to drift around corner 4 but stopped. :laugh:
:laugh: What Stan has a GTR ? :laugh: lols
Nice work Ando in the Ceffy 1.58.
Oh how good was the A4? :laugh: So gracefull as it zoomed around.
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
