guys try some of the other car carries like scots transport etc.
and duncan was it you that was telling me the other day how snowman couldn't drive a greasy stick up a dogs a55?
bring it on mexicans!
and troy since you are just a sydney boy stuck in melb behind enemy lines you can even borrow my GTST for the day since i'm sure your never ending project will not have ended. hehe i'm serious though.
try these boys:
http://www.movingcars.com.au/
http://www.toll.com.au/contact/logistics_automotive.html
http://www.advancecarcarriers.com.au/
in all seriouness though we need a few quick imported GTRs to show some cocky GTSTs a lesson or two.
If we are Mexicans to you guys, then maybe NSW are Canadians to the Vic guys???? ;)
Aren't Canadians weird french guys, with small balls :D ????
  • Replies 42
However - if I can get something organised for Wakefield then the 8th is still a possibility as it would be great to be there with SAUNSW.
Please keep us informed of your proposed Wakefield dates, ive got a lot of interest for another Wakefield day from both NSW AND QLD members ;)
PM me , or just post in our exec section, like you usually do :D
Yeah I'm writting something in there now.
Last night i was having a long hard think about the best way to spend what little money i have late this year...and trips like this and the PI 6 hour are better value for money then Dutton:( But i have committed to Dutton so Snowloughcan beat, well at least one car.
Decisions, decisions...as for accom on these trips. I may be able to help a few out with accom with family and friends.
For you guys not familar with Sydney, there is a great Hotel 500mtrs away from the track with plenty of night life. There is plenty of loving goign around with the ladies at night as well, how can you go wrong?
...and at the end of the day, i will be doing it the cheapest way possible...so that will mean driving up. The money i save is another No Speed day at Wakefield, or a Friday at Winton as i drive up :D
I want access to your Exec section again.
I used to have it... but its gone ;)
Fun times of sections past lol
it's ok Ash - all they talk about in there now is about how useless they are at organising a motokhana day.
:D
I used to have it... but its gone :D
Show me yours and ill show you mine
/young kid voice
:D
I got some :D
Anyways - these guys shit me so we need to teach some lessons.
So - who from Vic would be interested in attending this event. We can also do a day at Wakefield on the Monday and/or Tuesday for $130 added to the event. The rest of the details we can sort out if there is enough interest.
Oh - and we've been promised a TV so we can see whats happening up the hill.
Ok - it seems we have been disallowed from this anyways now (Not SAU NSW fault but the fault of the people running the event) - so we'll stick to my original plan of a Nov trip.
I'll post up the planned details when I get them finalised.
bugger...
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
