Hi Everyone,
I am thinking about a change of job, Im a bit tired of being taken for granted at my current workplace (whom shall remain nameless for the moment) working as a field technician - I am good at what I do and I always have good feedback, but I keep getting sent to jammed printers and delivery jobs, its getting a little frustrating... Anyhow, I am great on a helpdesk, good with people and I have great fault finding skills, so if your workplace is in need of an IT tech' I would appreciate the head's up about where you are and who to talk to so I can be Johnny on the spot with my resume :D Please feel free to pm me here
Thanks muchly,
Dave
https://www.sau.com.au/forums/topic/125009-it-jobs-in-hobart/
I take it you already have a degree or tafe qualifications? If not the Education Department takes on new trainees at the start of each year. It shit money to start off with but you can work your way up.
http://www.jobs.tas.gov.au/
Do a search under IT for details
you don't need a UNI degree for a NC job, NC is pretty basic in the sceme of things. NSO jobs arn't too bad, the DoE just give preference to trainee's for the positions. But you will get taken for granted where ever you go, IT people are treated like shit.
All I heard was "wah wah wah" :O
    • Curious to why you're not getting Jesse to do the exhaust, seeing that he has just done 2 GTRs with Aes valves.
    • What extra parts are you thinking you'll need to run e85 compared to e30?
    • I'm not aware of e30 in Australia, but I'm pretty sure e85 is still around. You really want a setup with an ethanol sensor so you can run any mix of ethanol depending on what you can access. Fuel Check NSW app shows 14 site in sydney metro with e85. What are you adding, will you put in bigger turbs too? Apparently the wastegates are pretty small and can't bypass enough as you run more boost.  I'm sticking to 1.3 bar with 98 on the standard turbos with my tune on advice from the tuner, and boost drops significantly in the top end; apparently larger turbos with larger wastegates are needed to get anywhere meaningful from there.
    • Amazing work Duncan! It is never easy to pick up someone elses project and work all the parts out that are missing
    • Hey Ppl,   I am about to tuned my Infiniti Q60 with E-85 and if you can tell me some location where I can top up my car that would be great.   But my other question, is E-30 available because this tuned requires less mods parts and any info you can offer would be greatly appreciated too!!
