yeah well i've been battling in my garage around my GTR gearbox for 6 months now, it'll be good to get some space back. also i think my transmission is starting to give up, it's a little jerky in the mornings and sometimes hangs in gears when i floor it. 180,000km proabbly does that.
  • 2 months later...
Here are some pictures of the new handbrake bracket and where it gets mounted in the car
The bracket needs part of it removed. It is made up of 2 peices spot welded together. The part in the photo with the part number is not need as it is already in the car mounting part of the air bag sensors. remove it from the bracket by drilling out the 2 spot welds.
There is also a mounting bracket for the auto centre console welded to the gearbox tunnel. This will need to be removed to mount the handbrake bracket. Drill out 3 spot welds.
The pic's are of a series 2, just incase a series 1 is different
thanks darrin great timing :huh:
One small problem
I have a r34 handbrake which is identical to a R33 one
One of the two mounting lugs on the handbrake will need to be bent to the right angle to match the bracket.
The Stagea handbrake must be slightly different
Duncan, when you're ready I'll come around and pull the centre console off my car for you so you can see how it is all set up... I've already got heaps of photos up in one of the threads, but if worst comes to worst, it only takes about 20mins to get everything off, so meeting up with you and pulling the car apart is a minor issue.
Who has fitted a manual pedal?
I tried to remove the auto one tonight. What a bitch
I have removed the 4 nuts that hold the brake booster and also removed the brake booster
I have dropped the steering column down get to the last bolt that holds the brake pedal bracket.
The last bolt is above where the brake light switch is, but you can not get access to the bolt as there is a a/cond duct in the way. I have tried to remove the duct with no luck. I t this satge it looks like I will have to remove the whole dash, which I am noy keen to do
The other option I thought of is to modify the auto brake pedal while it is still in the car. The only difference between the auto and the R33 manual pedal is the foot pad size and the auto pedal has a approx 10mm offset in the leg down near the foot pad. My Idea was to cut/grind the foot pad down to the same size and location/spacing between the clutch and accelerator pedal as the manual one
What do you guys think?
You can get the pedal off without taking the dash out. Ask Beastian, he's done it.
If I rip out (possibly distroy) the plastic a/c duct I can get to the last bolt, but I do not want to damage it.
I may have another look tomorrow with more day light to see what is needed
I didn't find it that hard to get to the bolt above the A/C duct. Just had to push it out of the way a little, used a socket with extension and forced it onto the bolt.
I found it more difficult to actually get the pedal assy out, and the new one in.
I thought I would add this photo I found of a car in Japan with a auto centre console that has been modified to suit a manual gear box and hand brake. I think I could be done better, but it looks possible
    • Details: Turbo Borg Warner EFR 9180 with 1.05 rear housing Upgraded TurboSmart integrated BOV Sanded and powdercoated compressor cover in gloss black Elbow welded with wiggins clamp Speed Sensor(Not included) (Can include oil drain(heat wrapped + titanium intake pipe with almost new filter for a tad extra). Manifold: 6 Boost RB26/30 twin scroll manifold  e-MAP ports drilled into both scrolls(I was using the TAARKS EMAP KIT) Turbo is in excellent condition. Always used Penrite 15w50 Racing oil(Changed less then 2000ks). Also using the Turbosmart OP regulator and filter. Downpipe: 4inch Stainless steel with VBand inlet and outlet clamps(included) Heat wrapped Dual ports for Dyno/Wideband usage Will throw in free 2.5 inch intercooler pipe(2.5inch From turbo outlet to 3.5 inch intercooler) - Powder coated black. Turbo made 563rwkw on mainline hub dyno at around 24-25psi boost - Pump fuel. Will def make over 600kw on e85. Didn't bother as my e-MAP was through the roof with my setup sitting past the choke line. I have a cnc ported and fully built head on my 3.2. Turbine speed saw max of around 109k rpm. I'm running this on my R32 GTR, with AC, and the original power steering pump. The manifold clears the AC lines, ABS, and everything else. Although I had new AC lines because I just wanted new ones and I heat wrapped them as well. This will make more power on a slightly lower capacity motor with a higher PR. And I have since upgraded to a G45-1500. Have pics and videos if need be.  Absolutely nothing wrong with setup. Turbo is in perfect condition. No shaft play or oil leaks at all. All the work was professionally done. The transient response of this is fkn amazing. I cannot rave more about this turbo. If I wasn't chasing 4 figures, I would have kept it. $5000 NZ. Located: Auckland, New Zealand.
    • I particularly like the look of the John Player Special team. (Thumbnail isn't different but hit play for the clip)
    • Such a cool collection of cars back then.
    • Mystery solved, thanks bro Bit of a strange mix, but i dont mind it, still looks good.
    • nah no problems with bearings or hubs.  just the water pump leak and my AC death
