yeah well i've been battling in my garage around my GTR gearbox for 6 months now, it'll be good to get some space back. also i think my transmission is starting to give up, it's a little jerky in the mornings and sometimes hangs in gears when i floor it. 180,000km proabbly does that.
  • 2 months later...
Here are some pictures of the new handbrake bracket and where it gets mounted in the car
The bracket needs part of it removed. It is made up of 2 peices spot welded together. The part in the photo with the part number is not need as it is already in the car mounting part of the air bag sensors. remove it from the bracket by drilling out the 2 spot welds.
There is also a mounting bracket for the auto centre console welded to the gearbox tunnel. This will need to be removed to mount the handbrake bracket. Drill out 3 spot welds.
The pic's are of a series 2, just incase a series 1 is different
thanks darrin great timing :huh:
One small problem
I have a r34 handbrake which is identical to a R33 one
One of the two mounting lugs on the handbrake will need to be bent to the right angle to match the bracket.
The Stagea handbrake must be slightly different
Duncan, when you're ready I'll come around and pull the centre console off my car for you so you can see how it is all set up... I've already got heaps of photos up in one of the threads, but if worst comes to worst, it only takes about 20mins to get everything off, so meeting up with you and pulling the car apart is a minor issue.
Who has fitted a manual pedal?
I tried to remove the auto one tonight. What a bitch
I have removed the 4 nuts that hold the brake booster and also removed the brake booster
I have dropped the steering column down get to the last bolt that holds the brake pedal bracket.
The last bolt is above where the brake light switch is, but you can not get access to the bolt as there is a a/cond duct in the way. I have tried to remove the duct with no luck. I t this satge it looks like I will have to remove the whole dash, which I am noy keen to do
The other option I thought of is to modify the auto brake pedal while it is still in the car. The only difference between the auto and the R33 manual pedal is the foot pad size and the auto pedal has a approx 10mm offset in the leg down near the foot pad. My Idea was to cut/grind the foot pad down to the same size and location/spacing between the clutch and accelerator pedal as the manual one
What do you guys think?
You can get the pedal off without taking the dash out. Ask Beastian, he's done it.
If I rip out (possibly distroy) the plastic a/c duct I can get to the last bolt, but I do not want to damage it.
I may have another look tomorrow with more day light to see what is needed
I didn't find it that hard to get to the bolt above the A/C duct. Just had to push it out of the way a little, used a socket with extension and forced it onto the bolt.
I found it more difficult to actually get the pedal assy out, and the new one in.
I thought I would add this photo I found of a car in Japan with a auto centre console that has been modified to suit a manual gear box and hand brake. I think I could be done better, but it looks possible
    • Im not entirely sure exactly what or where its leaking from, he started to pull the boots to swap to my new tie rods + ends and it just vomited fluid, so he closed em up up, swapped the rod ends to the old rods and let me know so I can figure a solution out, im guessing its all origional as as I passed 103k miles earlier this year im sure its just in need of a full overhual/rebuild anyways.    If i could just yank it off and be good it wouldn't be an issue to ship it out and wait for the turnaround but the guy I work with doesnt really have space to keep my car for a week or two at a time, would rather drop it off and have a replacement ready to drop in
    • What do you mean by "seals"? Internal hydraulic seals (ie, is it leaking PS fluid?) or the rack boots that close the rack onto the tie-rods? Because the former is a rebuild, and the latter is trivial that you or any nearby mechanic could do. Dunno about the cowl. Just buy what you think is required and get anything else you find/break afterwards. Wing? Dunno. Don't like R33s enough to pay attention to them. Mirror glass is just glass (on the surface that you want to polish). Go for it.
    • Hello! Long time lurker, been using the forums to address concerns and questions from afar for a while but I've struggled to find some answers so I guess its about time I made an account and formally asked some more knowledgeable people, since finding local skyline owners is hard (and shops that are knowledgeable or trustworthy to work on 'rare' cars are non existent out where im at, as skylines are quite uncommon to find in the wild around here). So the main 3 questions I have, 1: Steering rack has blown seals, well.. they kind of hold but they are not sealed properly anymore and as my R33 is my DD, i cant exactly rip the rack out and send it off or attempt to fix myself. As most refurb ones are around $1,100 or more shipped, and I have other things I need to work on around the car, I was seeking clarification on whether an S15 rack will more or less bolt right in, and whether a common mechanic could do any other required work to get it to fit. I ask, as I've found a supplier than can sell a manufactured as oem one for around 400, if not I'll likely order a used one from Jacks JDM, and take a risk on the seals there. The second question i have is that im replacing the front wiper cowl and have planned to buy 4 new clips and a new center clip but wasnt sure if there were any other clips that would also need to get replaced while I was at it. Given im sure any that are there now will simply break when I remove the old cowl... Last thing would be a fairly straight forward question, i think. If I manage (strong if, finding one has proven to be a pain) to find a R33 GTR spoiler/wing will it require much modification to bolt to a S2 R33 GTST? I've read the bolt patterns dont match but otherwise would bolt in, only options I have found with much luck is China stuff on ebay and carbonetics, which has a nice $650 shipping fee... so if anyone has any pointers where a US chap could locate one that would be great Random side question as well, the mirrors as I understand are mirror glass, and as im planning to polish my windows from water spots and surface scratches, i was hopeful cerium oxide would be fine for them too, as my research points to, but clarification is always nice. Any pointers would be appreciated, and while I have scoured the internet for answers if I missed a prior post somewhere that may answer these directly please point me towards it, as i must have simply missed it. I have seen a post here or there that has mentioned it, but I usually get 50-50 answers, or half answers... I dont have a lot of fab experience or mechanic experience, outside of hydraulic and pneumatic stuff I did in the military and with how hard it is to source stuff in the US, id rather not wing it and hemmoraghe money lol. Thanks guys! Sorry for the monumental first post haha
    • Yep, there's a very minor drift left that happens a few seconds after letting go of the steering wheel, but not enough to bother me. Enjoying the car still!
    • Got you mate. Check your email!
