yeah well i've been battling in my garage around my GTR gearbox for 6 months now, it'll be good to get some space back. also i think my transmission is starting to give up, it's a little jerky in the mornings and sometimes hangs in gears when i floor it. 180,000km proabbly does that.
  • 2 months later...
Here are some pictures of the new handbrake bracket and where it gets mounted in the car
The bracket needs part of it removed. It is made up of 2 peices spot welded together. The part in the photo with the part number is not need as it is already in the car mounting part of the air bag sensors. remove it from the bracket by drilling out the 2 spot welds.
There is also a mounting bracket for the auto centre console welded to the gearbox tunnel. This will need to be removed to mount the handbrake bracket. Drill out 3 spot welds.
The pic's are of a series 2, just incase a series 1 is different
thanks darrin great timing :huh:
One small problem
I have a r34 handbrake which is identical to a R33 one
One of the two mounting lugs on the handbrake will need to be bent to the right angle to match the bracket.
The Stagea handbrake must be slightly different
Duncan, when you're ready I'll come around and pull the centre console off my car for you so you can see how it is all set up... I've already got heaps of photos up in one of the threads, but if worst comes to worst, it only takes about 20mins to get everything off, so meeting up with you and pulling the car apart is a minor issue.
Who has fitted a manual pedal?
I tried to remove the auto one tonight. What a bitch
I have removed the 4 nuts that hold the brake booster and also removed the brake booster
I have dropped the steering column down get to the last bolt that holds the brake pedal bracket.
The last bolt is above where the brake light switch is, but you can not get access to the bolt as there is a a/cond duct in the way. I have tried to remove the duct with no luck. I t this satge it looks like I will have to remove the whole dash, which I am noy keen to do
The other option I thought of is to modify the auto brake pedal while it is still in the car. The only difference between the auto and the R33 manual pedal is the foot pad size and the auto pedal has a approx 10mm offset in the leg down near the foot pad. My Idea was to cut/grind the foot pad down to the same size and location/spacing between the clutch and accelerator pedal as the manual one
What do you guys think?
You can get the pedal off without taking the dash out. Ask Beastian, he's done it.
If I rip out (possibly distroy) the plastic a/c duct I can get to the last bolt, but I do not want to damage it.
I may have another look tomorrow with more day light to see what is needed
I didn't find it that hard to get to the bolt above the A/C duct. Just had to push it out of the way a little, used a socket with extension and forced it onto the bolt.
I found it more difficult to actually get the pedal assy out, and the new one in.
I thought I would add this photo I found of a car in Japan with a auto centre console that has been modified to suit a manual gear box and hand brake. I think I could be done better, but it looks possible
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
