just a word of advice
take your steering wheel off
THe same bit you use to take off the airbag module under the console, is the same type used on the side of the wheel to hold on the horn pad. then its a 21mm nut under the horn
then disconnect the two connectors and yank it off.
Well just to be careful, when I removed my steering wheel, I disconnected battery, then hit the brakes, tried turning the headlights on, to drain any residual power left in the system, then gently unplugged the airbag control unit, then unplugged the airbag, and did the reverse to hook it all back up, hooray, no airbag error light after 5secs of the car running.
Well I didn't need to anyway, I have the new brake pedal box installed and the steering wheel back together.
This is a milestone for me as I've been doing everything at night with a hand held torch. I have many cuts and bruises now.
One of the hardest thing I found to do was removing and refitting the smallest part, the saftey pin on the brake pedal to booster rod.
lol, i just turned the car off, and unpluged the airbag.....i dont think ive ever unhooked hte battery for it
and no airbag light....cause there isnt wont
Do you mean there isnt one? Yes there is, middle of the dash in the centre of the speedo.
That wasn't too bad for me. They hardest bit I found was getting that top bolt back into the pedal box. It took me about half an hour just to get that in. apart from that, I found that once you've undone all the bolts you can twist the whole steering column to get the bracket out of the way, and then the pedal box goes in really easily. I wish I'd figued it out while I was taking the old one out.... oh well, we live and learn
I got my clutch in the other night, but forgot to stick a picture up. I managed to install the master cyliner, then realise I'd forgotten to put the clutch line in, which wasn't possible to install with the master cylinder in. So out it came, I put the line in an then back it went. All one now, however the engine is in pieces and I'm short a turbo, so no gearbox yet :D
Well I know it's not directly related to the Manual conversion,but I got my new turbo in last night. First time it seems really hard, but if I had to do it again it would be so much easier now I figured out the hard bits.
I'm going to clean up the gearbox next, then next week some time book her in for a gearbox swap!
    • Stock equivalent turbo replacement is a bit of a nightmare. The old Hitachi ceramic things were pretty good for their time, but they have primitive, vintage aerodynamics. The only thing they have going for them is a light turbine**, and there are plenty of other light turbine options these days, in both materials and CNC manufacturing methods. So, the old stocker makes absolutely no power at all compared to its physical size and its (not very low) boost threshold and response. ** and the ONLY thing that was good about the ceramic turbine was that it was light. In all other respects it is a nightmare. To get a turbo that is anywhere near equivalent in terms of power capacity (ie, to avoid it being "bigger" and needing tuning/fuelling/etc) you have to physically downsize. And that is not a "stockish" replacement. Doesn't just fit where the old one did. At least a frame size down, probably need a new dump, probably need new inlet and outlet piping made on the compressor side, new hose connections as D said above. I say, if you have to suffer that much work, you might as well do the same work to fit an even bigger (than stock) turbo, have more power (and hence have to do injectors, ECU, etc), and love life, instead of suffering with stock power levels. Or, you get a light highflow from someone like Hypergear. A highflow that has not been pushed too far from stock. There are still modification consequences here though. HG's cores are smaller than the massive Hitachi core, so it is shorter, moves the compressor housing backwards and requires mods to the air side piping. Plus new hoses. Looks stock, mostly fits where the stock one did (with the previous caveats mentioned), makes a bit more power but can be run at stock boost levels and not cause too many ECU problems. But, seriously. It's 2024. Like - 25 years since the R33 came out. It's time to put an ECU in it. I Nistuned my car (on RB20 ECU then later again on the Neo ECU) and it was the single best thing possible for minimal money. Dial out the R&R bullshit, fix up the fuelling and timing to make it more efficient for normal driving (cut fuel consumption by >10%). Nistune is not an option for you unless you change the ECU, so you might as well just do a standalone. it will be worth it. And then you can tune it up to the limits of the injectors and AFM, which is pushing 200rwkW and enjoy some actual squirt, instead of the lazy barge-like motion you get from a stock engine, turbo and management.
    • He can't post pics until he's at 10 post count.
    • Welcome James.....will be interesting to see how much fun there is in the project. .....where's the pics?
    • Your profile doesn't say where you are, but you can get your current turbo rebuilt by any competent turbo shop, places like Precision Turbos or GCG They can replace the core with a modern ball bearing unit and should be able to source same or slightly larger wheels to fit in you housing. Note if you change the core you may need new oil and water lines too
