there is probably a specific seal part, there is on the gtr and navara....i dont have one yet either.
problem is if you go silicone you need to be able to remove it again, the factory ones are a rubber seal with a bracket that screws into chasis
Yeah I think that a bit too much of the transmission tunnel was cut away to fit m gearstick in, so I don't know if the part will fit. I'll try and get one anyway, I'm sure I can fit it somehow.
Anywho, the car drives much better with the manual in, I'm so excited. all I need now is to fix the R&R problem I'm having due to my new turbo.
Hey Darrin, I bought a brand new S2 Stagea handbrake lever, through japanparts.com. Was around $140, and another thing, I've enquired about stagea parts through Nissan Aus, and they've told me they're not available, then I've enquired with japanparts.com, and they've been able to supply them.
I'd give them a try, takes no longer than through nissan aswell, bout 2 weeks.
S2 handbrake P/N: 36010-0V705
36010-0V705 is no longer available, so I have order 36010-0V700 which is suppose to be the same or very similar for a stagea after 10/98
I have order thru japanparts as Nissan aust do not have a listing or pricing for these parts.
Does the series 1 have a hole at all to start with, or did you need to make the existing hole bigger?
I removed my series 2 tiptronic selector last night and there was what looks like a big enough hole already for the manual gearbox. Also the 4 bolts holes that hold the selector in place line up with the manual rubber boot around the gearstick perfectly.
Ah! that's the part I need! I'm just using some rubber I got from Clarks and some silicone to fix it, I don't think I need a boot that hefty.
This is a boot out of a skyline. All skyline's and silvia's are the same so you can use either one
Terminal, did you have to cut the floor???
Yeah mine had to be cut, so I don't think that boot would fit unless I welded in another piece of metal as Brendan describes. I'm not too fussed on that 'factory' look for my conversion so I'm just going to cover it with some rubber and sound deadening. It's all covered by the console anywho :)
I've just looked through my emails from when I purchased mine, and 36010-0V700 is what I ended up with, it's the replacement for the part number 36010-0V705.
It fits perfect with no problems at all.
got mine back this morning, and it is great to drive.....so much more fun with the bloody auto gone.
The clutch is shuddering a bit I hope that is just the old flywheel i used, but otherwise it is sweet to drive now.
Only one real problem, the handbrake I have sits too low in the console - need to raise it by prolly 1cm so it sits right. Otherwise everything is sweet
well had even more fun today, we knocked out about 25 laps of wakefield park this afternoon, some in the damp, some dry. Gary's suspension is excellent but these cars really need more power than standard. Manual gearbox was beautiful.
But it was a pain in the arse to get moving for hill starts when I was towing the GTR yesterday.....price you pay I guess
Man, I'm hanging to get out on the track in the car, but I want to have all my gauges in first and at least get the suspension mods started. Maybe for the Texikhana I'll be ready... I might have even put the front split/dump pipe on.
Hahaha, as for the towing with the manual, you know what Gary's gonna say...
lol he's already said it, he was there with Matt's gtst yesterday :P Best lap I did was a 1.20, it would have had a 1.18 in it if I could have put together a clean lap....but thats still 3-4 sec slower than an equivalent gtst...you can really feel the extra weight.
  • 3 weeks later...
Got my manual gearbox in last night. (what a pain in the arse. The box I have used is a 93-94 32gtr pull type box which has a speedo cable drive.
The Stagea and r33 GTR box uses a electronic speedo drive.
Most people here have used a R32 box in their conversion, so what electronic drive have you used
The auto stagea electronic drive will not fit.
    • This is awesome.
    • Thanks for the quick replies guys its appreciated. A small extension was welded onto the standard 6boost external gate pipe which you can see where the pipe goes from black to stainless just below and to the right of the rear housing in the first picture. Overall I would say the flow is pretty good other than 6boosts choice to come straight off the collector at a decent angle.. Not sure why I went with two valves, I originally replaced the stock twin bovs with the GFB when I had the twins on. When I purchased the EFR it came with the Turbosmart Kompact BOV so I figured that would be a better option than the stock EFR Bov. I don't believe the Turbosmart BOV is adjustable? When I get the spike and then sudden dip in boost pressure, the turbo speed does drop as well. Stock head size wise however I believe it has Neo Turbo springs and a Neo Turbo intake camshaft and an aftermarket exhaust camshaft in the vicinity of 260 degrees. We didn't try a different MAC valve, we tried two different ways of plumbing it and we also tried removing the mac valve entirely and just having the boost source from the turbo directly connected to the wastegate and it still spiked / dropped and exhibited the same behaviour. Standard R33 GTR 5 speed tansmission. I'm running a Haltech Elite 2500 and can provide some logs if you. I understand what you're saying in that it looks like an auto plot however no, it's still a manual and it just has a lot of torque down low, for all intents and purposes it's a very impressive street car. I've attached a photo of the quickbitz dyno plot which was when the only difference is I was running -5 twin turbos with a mac valve. As you can see theres a decent dip in AFRs between 125kmh and 135kmh. Our problem now is not that the AFRs are dropping, just the boost pressure is dropping, however it is evident in the same RPM range of the map, coincidentally or not.
    • What transmission are you running?  It's a bit tricky with the scaling, but at face value the power "curve" looks more like a "line" which is a bit odd... basically a lot more like a dyno plot I'd expect with a highish (compared to a factory auto) stall torque converter type setup. If this is running an auto then this kind of boost control challenge is definitely a thing, the rpm scale on the dyno doesn't reflect what the engine is actually doing (unless the dyno has access to the engine's ACTUAL speed electronically) and what you'll get is a big rpm flare up as the engine torque launches past the converter pump's ability to resist torque at that rpm, then as the converter starts picking up rpm it will kinda even out again and the engine rpm will pick up more steadily. The trick with this "flare up" is if it's kinda near the boost threshold for the turbo then the engine's airflow requirements to maintain the previous boost level will outrun the turbo's ability to supply that boost - so you end up with a natural flattening off, if not dip when that happens.   If you are running closed loop, or even tune the "feed forward" wastegate duty cycle to deal with that rpm spike then when the engine starts settling to a more typical climb you'll actually have a situation where the gate is "too closed" and boost will run away for a bit, then have to pull down again.      It's not trivial to get this perfect as most boost control systems are generally expecting more predictable engine rpm rates of change, but if you *know* that's whats going on then you can at least "accept your fate" and realise getting that area perfect is kinda chasing your tail a bit, and assume that if the rest is working sensibly and the spike/dip isn't completely uncontrolled then you should be good. Sorry if I've gone off on a tangent, but the dyno plot and boost control behaviour look a LOT like what I've seen tuning autos in the past. What ECU are you running? Could possibly be convinced into looking at logs if I get too bored this weekend haha.
    • A few things that seem a bit off here. - why is there 2 BOV’s?  - the turbo smart BOV on the compressor housing, is it turned up ALL the way? I have seen this become an issue on old man Pete’s car. It would push open and recirc, turbo speed would rise and the boost pressure would do weird things. - stock head? Does that include springs? - tried a different MAC valve? Is it plumbed correctly?
    • Photo of manifold showing gate location? I mean, it's 6Boost, so we probably shouldn't be worrying, but always wroth knowing what the layout is. Plumbed back to atmosphere? Or into the dump?
