I think very few have used a recessed MC, it is a lot harder to do and not really necessary because all it does is add a clutch booster....they are fine without. Mine is a 34 MC and bolted straight on (although like Bob I have tight clearance in the engine bay and a FFP)
I can't remember any tricks internally (drill through and bolt in) but can take some pics if you have something specific you want to check out?
Im using an R34 clutch pedal and master cylinder. The bottom holes of the pedal bracket don't line up, but the top 2 and the single one at the top all do. Im going to weld on some plate at the bottom of mine then drill holes to suit, although currently i have just the 3 and its doing fine.
If you could get some pictures of the clutch pedal mounting point that would be great! All the holes I have line up however the bracket where the footbrake bolted onto is fouling on the bottom of my clutch pedal. I'm tight for clearance is well in the engine bay but nothing serious.
  • 5 months later...
I hate bumping up such an old thread. But  I've got a c34 s2 rs-v (rwd) and I'm doing research to get it manual convo.
I'm wanting to know what tail shaft to use? I assume the auto one won't fit. I'm looking at getting a r33 gtst gearbox. will i need to cut and shut?
I have tried researching but there is so little info on factory rwd stageas.
Just search " R33 manual conversion". The hardest bit is getting a good R33 big box (the lighter one won't last). I don't know what you are planning to cut and shut unless you use a GTR box (because they are easier to find and cheaper). Your driveshaft may well be fine. Do the search and have a read.
  • 7 months later...
Hwy guys i have a 97 c34 s1
And have bought a full manual conversion out of a 99 s2 rs4s and am havung trouble working out whoch plug on the gearbox os the reverse wiring and where do i run it to on my factory auto wiring
Any help would be great
Cheers pete
  • 2 years later...
  • 1 month later...
53 minutes ago, Meljo said:
Hi mate , I have got an 1997 auto Rwd stagea does (R33 GTS4 or GTR Box) manual still works on the rear wheel drive?
I’m new with cars 0.0
You need a rwd box, there is no room for a transfer case if you have a look
  • Thanks 1
  • 6 months later...
    • So where is this message group so we can organise another meet? Keen to come along and catchup. Might eventually be in a skyline again next year, but the Mustang will have to do for now. Also need to get the WRX back on the road. Stupid f**king money pit that thing is.
    • Stock equivalent turbo replacement is a bit of a nightmare. The old Hitachi ceramic things were pretty good for their time, but they have primitive, vintage aerodynamics. The only thing they have going for them is a light turbine**, and there are plenty of other light turbine options these days, in both materials and CNC manufacturing methods. So, the old stocker makes absolutely no power at all compared to its physical size and its (not very low) boost threshold and response. ** and the ONLY thing that was good about the ceramic turbine was that it was light. In all other respects it is a nightmare. To get a turbo that is anywhere near equivalent in terms of power capacity (ie, to avoid it being "bigger" and needing tuning/fuelling/etc) you have to physically downsize. And that is not a "stockish" replacement. Doesn't just fit where the old one did. At least a frame size down, probably need a new dump, probably need new inlet and outlet piping made on the compressor side, new hose connections as D said above. I say, if you have to suffer that much work, you might as well do the same work to fit an even bigger (than stock) turbo, have more power (and hence have to do injectors, ECU, etc), and love life, instead of suffering with stock power levels. Or, you get a light highflow from someone like Hypergear. A highflow that has not been pushed too far from stock. There are still modification consequences here though. HG's cores are smaller than the massive Hitachi core, so it is shorter, moves the compressor housing backwards and requires mods to the air side piping. Plus new hoses. Looks stock, mostly fits where the stock one did (with the previous caveats mentioned), makes a bit more power but can be run at stock boost levels and not cause too many ECU problems. But, seriously. It's 2024. Like - 25 years since the R33 came out. It's time to put an ECU in it. I Nistuned my car (on RB20 ECU then later again on the Neo ECU) and it was the single best thing possible for minimal money. Dial out the R&R bullshit, fix up the fuelling and timing to make it more efficient for normal driving (cut fuel consumption by >10%). Nistune is not an option for you unless you change the ECU, so you might as well just do a standalone. it will be worth it. And then you can tune it up to the limits of the injectors and AFM, which is pushing 200rwkW and enjoy some actual squirt, instead of the lazy barge-like motion you get from a stock engine, turbo and management.
    • He can't post pics until he's at 10 post count.
    • Welcome James.....will be interesting to see how much fun there is in the project. .....where's the pics?
