No idea sorry, I definatly have the R32 box, and it'll be driving past your way on saturday with a new owner at the wheel too :( Unless you want to miss the stagea meet and come over to the northside?
I put an R33 GTR pull type box in mine, I swapped the R33 sender for the Stagea auto sender.
The wheels were different sizes, but they interchanged with no problems, works fine
and indicates the exact speed as it did before the conversion.
  • 2 years later...
G'day I would like to add this link with a few pics of the holes cut in the tranny tunnel for the manual box as well as the handbrake mounting position. Hope this helps someone.
http://www.skylinesaustralia.com/forums/Rb...ed#entry4850649
Cheers,
Jon.
  • 1 year later...
  • 4 weeks later...
I will be using a R34GTT clutch pedal and MC with the stock GTR slave cylinder or maybe a ¾ Nismo slave cylinder so no booster like a GTR.
Sorry to bring back an old thread, but am I right by this that if you use the R34 clutch pedal and master cylinder that you don't need to worry about the clutch booster and needing to recess it in the firewall?
  • 3 weeks later...
i just finished my manual conversion on my 96 rs4, i used a r34 gtt clutch pedal and a r33 master cylinder and didnt need a booster and you dont need to recess it. only the gtr clutch pedal is recessed into the firewall, i think all gtr clutch pedals are recessed, same with the autech gtr stageas. so if you have a r34 gt-t clutch pedal you should have no problems, they are hard to get tho i waited 6 months and didnt see 1 any where so i had to order it from nissan $780 NZD :(
should be lots around after the earthquake and all. hope this helps,
Johan
  • 1 year later...
Hi all, Just thought id add in my version.
ive just finished my auto to manual conversion, mine is a late 97 RS four, rb25det, series 1.
the parts i used are as follows.
- R32 gtr gearbox, $450 ebay
- R32 gtr slave cyl, come with the gearbox!
- R33 gtst clutch pedal and master cyl. $150 ebay,
- R33 gtst brake pedal, purchased with clutch pedal,
- custom made braded clutch line from pirtek (hyd hose company for those who dont know) $85,
- hard core cluth company clutch kit, cushion button, (half organic/half brass button) $450 ebay shop who sells clutch kits.
- rb30e standard fly wheel and bolts. come off a spare engine i bought for $100,
- R33 gtst hand brake and cable, came with pedals i bought.
- R34 manual center console, $140 ebay.
- genunie nissan spigot bearing, $4.
- gen nissan hand brake mounting, $68
plus a few other odd bits.
apart from cutting the hole in the tunnel for the gear stick, and in the fire wall for the clutch MC, every part i used was a dirrect bolt together fit,
no modifying any part to get it to fit. the flywheel fitted well, (size etc) the clutch kit was originaly purchased for my rb30 GQ patrol
as they to use a FS5R30A trans.
the only real trouble i had was removing and re fitting the top bolt near the head at the top of the gearbox, it required some custome spanner fabricating!
the clutch kit has a 2100kg pressure plate, im not using a booster and it feels like a stock clutch, and drives like a stock clutch.
my speed sensor was a straight swap from the auto into the manual, and it reads correct.
the manual will require longer bolts, i had some layin around the shed from other projects, but you will need to get some.
just thought this may help anyone with questions as to what will fit there model of stagea if doing this conversion,
it took me 2 full days on my own with no instruction apart from what ive read on this forum!
just a good hint for people looking for rb parts, alot of other nissans use the same parts, ie gearbox, flywheel, spigot bearing etc
so shop around, for example a good clutch kit for a R33 gtst, $700-1000, good kit for a patrol, $450.
2nd hand flywheel to suit rb25 $200-300, flywheel from an rb30 at the wreckers $70!
do your research and be patient! good things come to those who wait and performance loves good preperation.
R34 console details too....I plan to use one in my next build
I looked into using one and measured it all up about 4 years ago....its not a direct fit
But some things you may live with when comparing a R34 $140 console to $500-700 for a stagea manual console
That's for real - just using the auto console myself!
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
