I think very few have used a recessed MC, it is a lot harder to do and not really necessary because all it does is add a clutch booster....they are fine without. Mine is a 34 MC and bolted straight on (although like Bob I have tight clearance in the engine bay and a FFP)
I can't remember any tricks internally (drill through and bolt in) but can take some pics if you have something specific you want to check out?
Im using an R34 clutch pedal and master cylinder. The bottom holes of the pedal bracket don't line up, but the top 2 and the single one at the top all do. Im going to weld on some plate at the bottom of mine then drill holes to suit, although currently i have just the 3 and its doing fine.
If you could get some pictures of the clutch pedal mounting point that would be great! All the holes I have line up however the bracket where the footbrake bolted onto is fouling on the bottom of my clutch pedal. I'm tight for clearance is well in the engine bay but nothing serious.
  • 5 months later...
I hate bumping up such an old thread. But  I've got a c34 s2 rs-v (rwd) and I'm doing research to get it manual convo.
I'm wanting to know what tail shaft to use? I assume the auto one won't fit. I'm looking at getting a r33 gtst gearbox. will i need to cut and shut?
I have tried researching but there is so little info on factory rwd stageas.
Just search " R33 manual conversion". The hardest bit is getting a good R33 big box (the lighter one won't last). I don't know what you are planning to cut and shut unless you use a GTR box (because they are easier to find and cheaper). Your driveshaft may well be fine. Do the search and have a read.
  • 7 months later...
Hwy guys i have a 97 c34 s1
And have bought a full manual conversion out of a 99 s2 rs4s and am havung trouble working out whoch plug on the gearbox os the reverse wiring and where do i run it to on my factory auto wiring
Any help would be great
Cheers pete
  • 2 years later...
  • 1 month later...
53 minutes ago, Meljo said:
Hi mate , I have got an 1997 auto Rwd stagea does (R33 GTS4 or GTR Box) manual still works on the rear wheel drive?
I’m new with cars 0.0
You need a rwd box, there is no room for a transfer case if you have a look
  • Thanks 1
  • 6 months later...
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
    • I would suggest equally difficult to find, perhaps edging to the SR. Turkey has almost exclusively Euro market cars, some Korean, few Japanese other than pedestrian shite. I guess they're probably losing the fight against Chinese shit like we are now too. I would vote for a BMW V8, found in a 540i in a wrecking yard somewhere in Deutschland (or possibly Albania).
    • A CigWeld EasyWeld 130 can be had from ebay for $360 delivered. Good for 0.6 to 6mm, which would be fine for my requirements. I guess that on top of that you would need to buy a regulator, hoses and wire. I already have gloves and an auto-darkening mask. How is the gas bottle charged? Do you rent it then pay for top ups?
    • RB20 being an option from factory would mean no custom parts or fabrication required, just have to collect the right bits. Probably would be the easiest option I reckon for a motor swap. How common are SR20s vs RBs in Turkey?
