yeah well i've been battling in my garage around my GTR gearbox for 6 months now, it'll be good to get some space back. also i think my transmission is starting to give up, it's a little jerky in the mornings and sometimes hangs in gears when i floor it. 180,000km proabbly does that.
  • 2 months later...
Here are some pictures of the new handbrake bracket and where it gets mounted in the car
The bracket needs part of it removed. It is made up of 2 peices spot welded together. The part in the photo with the part number is not need as it is already in the car mounting part of the air bag sensors. remove it from the bracket by drilling out the 2 spot welds.
There is also a mounting bracket for the auto centre console welded to the gearbox tunnel. This will need to be removed to mount the handbrake bracket. Drill out 3 spot welds.
The pic's are of a series 2, just incase a series 1 is different
thanks darrin great timing :huh:
One small problem
I have a r34 handbrake which is identical to a R33 one
One of the two mounting lugs on the handbrake will need to be bent to the right angle to match the bracket.
The Stagea handbrake must be slightly different
Duncan, when you're ready I'll come around and pull the centre console off my car for you so you can see how it is all set up... I've already got heaps of photos up in one of the threads, but if worst comes to worst, it only takes about 20mins to get everything off, so meeting up with you and pulling the car apart is a minor issue.
Who has fitted a manual pedal?
I tried to remove the auto one tonight. What a bitch
I have removed the 4 nuts that hold the brake booster and also removed the brake booster
I have dropped the steering column down get to the last bolt that holds the brake pedal bracket.
The last bolt is above where the brake light switch is, but you can not get access to the bolt as there is a a/cond duct in the way. I have tried to remove the duct with no luck. I t this satge it looks like I will have to remove the whole dash, which I am noy keen to do
The other option I thought of is to modify the auto brake pedal while it is still in the car. The only difference between the auto and the R33 manual pedal is the foot pad size and the auto pedal has a approx 10mm offset in the leg down near the foot pad. My Idea was to cut/grind the foot pad down to the same size and location/spacing between the clutch and accelerator pedal as the manual one
What do you guys think?
You can get the pedal off without taking the dash out. Ask Beastian, he's done it.
If I rip out (possibly distroy) the plastic a/c duct I can get to the last bolt, but I do not want to damage it.
I may have another look tomorrow with more day light to see what is needed
I didn't find it that hard to get to the bolt above the A/C duct. Just had to push it out of the way a little, used a socket with extension and forced it onto the bolt.
I found it more difficult to actually get the pedal assy out, and the new one in.
I thought I would add this photo I found of a car in Japan with a auto centre console that has been modified to suit a manual gear box and hand brake. I think I could be done better, but it looks possible
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
