Hey just wondering, people are saying change the gap from 1.1 to 0.8 how the hell do you do it? Use a fealer gauge to determain the size and just squish it down lol. I like to know how its done because my car has a very bad missfire at 3500-4000rpm and its pissing me off, the coil packs have been check and are all good and im using platnium plugs, ok my oxy sen is fuc*ed but thats been changed and no difference. I thought maybe because the 02 sen was rooted that coking of carbon on the plugs could be the problem but their fine now, but still have that missfire. The coils are indavidual ignitors so they dont have an ignitor seperatly, like on ser1 and early r33's.
I have a r33 1995 with a rb25det apparently ser 1.5. Can someone give me some true and related advice not just hand me over to another post please.
https://www.sau.com.au/forums/topic/125058-spark-plug-cap/
That's the only way that I know of gapping a plug... granted, i've never done it myself, but that's my understanding of how it's done. The metal is quite strong.
As far as the missfire thing... the coilpacks are the popular fault of the month. You could double-check this though. Mine used to missfire if I was in a tall gear and put the boot right in.
Get the motor nice and hot, then stick it in 4th at about 60km/h, then boot right into it. Mine would missfire lower in the revs when I had faulty coilpacks and did this.
https://www.sau.com.au/forums/topic/125058-spark-plug-cap/#findComment-2309154
Yes, use a feeler gauge to measure the gap, and either find a place to squish the tip against another surface or tap it on a surface, always checking again with the feeler gauge to see how close you are to 0.8mm. You don't need much effort to bring them closer so don't go crazy.
Conversely, do the right thing in the first place, and buy plugs that are already gapped at 0.8mm, saves you the hassle.
Fixxxer
https://www.sau.com.au/forums/topic/125058-spark-plug-cap/#findComment-2309460
To expand on this... if it's happening all the time, I'd guess the packs are faulty. Unless you are running really high boost, gapping the plugs down is a hack to try and fix the coil pack issue.
With a smaller gap, it takes less power to jump the distance, and you might be lucky that the distance is less than where the spark is currently jumping out of the packs. This will also give you a weaker spark and weaker burn... so if gapping them doesn't fix anything, check and fix your coilpacks, and put new plugs with the standard 1.1mm gap back in.
https://www.sau.com.au/forums/topic/125058-spark-plug-cap/#findComment-2309751
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
