Hey I have got a PFC and around 240rwkw... and my car uses a fair amount of petrol, when i am fanging it periodically fuel effiency can drop down to around 18L/100km and general town driving would see me get aroudn 14L/100km driving smoothly...
When i accelerate hard i can expect a moderate sized cloud of black smoke trailling behind me do to the car (r33gtst) tuned to run rich....
My question is why is it that there is a perception that the car should be tuned to run rich to the point where smoke comes out of the exhaust...?
I have seen porcche's and ferrari's launch off the mark and go for a good fanging without leaving a trail of smoke....
Is it just that i have a bad tune? or is it necesarry to run my car this rich?
your thoughts?
if you are getting unburnt fuel coming out the exhaust then it is running rich. it should be tuned so that the afr's are around the 11.8 to 12.0:1 range. easiest way to see what its like is to stick it on a dyno and see what the afr's are like.
They are at that range.... however i still get a fair bit off black smoke coming from the exhaust
I've seen exotics running rich on occasion too.
gotta burn fuel to make power, stoichiometric is 14.7:1 so even at 12:1 you are putting more fuel in than can be completely burnt. unless it's excessively rich i would not worry.
My car is tuned rich (CRD) and when I was getting my new cat-back exhaust fitted yesterday the bloke said that normally when he pulls off an exhaust they have about 1-2mm of black crap lining the insides where as mine has 3-4mm which he said was 'too' rich.
It does blow plenty of black crap when I give it a belting which does become expensive but then I read threads of engines blowing up due to bad tuning and I sorta forget all about my engine running so rich.
Is it really blowing that much smoke? If its
I see in the headlights of a car behind a hase of smoke that one could consider a cloud. On the dyno and my other half strapping it past from the side of the road there is zero smoke.
How long has it been since your tuner calibrated his o2 sensor?
  • 3 months later...
Accel pump settings are set high on a PFC. The setting is in Milliseconds, so if you change to a larger injector they will be way to big making the problem worse. And "no" the accel pump settings are not scaled when you change the injector size settings in the PFC.
This setting can give you the big puff of smoke when you first accelerate and cover the back of your car with black crap.
This puff should clear quickly to no smoke on gentle acceleration providing the rest of the tune is good.
Mike
Mike
I tend to agree with this.. I've pulled dialed mine back a little past ~1/2 of the std value and still haven't experienced any drivability issues.
Just remember that TOO rich slowly glazes shit up and = death eventually. You need to find that comfortable medium.
My car is running a Wolf and off boost is an absolute dream on fuel (500km to a tank city driving), on boost it uses more, blows a bit of black smoke but nothing exessive and pulls hard, back off boost, comes back to good fuel economy. Its making 274.8rwhp too out of a fairly stock RB20DET (exhaust, Wolf, RB25 turbo and fmic) and the car is happy as.
your thoughts?
strange u get better fuel econemy running it harder, than putting around, my car is total opposite. a little black smoke is normal from a highly boosted engine, as where then it would be practical to run it a little richer.
seems hes running it richer, so it doesnt lean out up top. leaning out is bad , but of course running rich alot is bad also, over time, it will wear out ur rings.
maybe try a new tuner. should be able to rectify that with ur PFC i would imagine.. just gotta find someone who knows how to tune the pfc properly.
Well I have 700CC injectors and dialled my Accel pump setting to 1.5ms at 1000rpm down to 1ms at 3&4000rpm, much better and no black puff or cloud when I drive away. The setting is best felt by the driver on the road of course but with only gentle acceleration. The bit you're feeling for is the very initial push as you just open the throttle. Slaaming the throttle open especially at rpm under 3000 allows you to feel no change regardless of setting.
Zero them out and gradually increase them and you will see what I mean.
Mike
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
