Hey I have got a PFC and around 240rwkw... and my car uses a fair amount of petrol, when i am fanging it periodically fuel effiency can drop down to around 18L/100km and general town driving would see me get aroudn 14L/100km driving smoothly...
When i accelerate hard i can expect a moderate sized cloud of black smoke trailling behind me do to the car (r33gtst) tuned to run rich....
My question is why is it that there is a perception that the car should be tuned to run rich to the point where smoke comes out of the exhaust...?
I have seen porcche's and ferrari's launch off the mark and go for a good fanging without leaving a trail of smoke....
Is it just that i have a bad tune? or is it necesarry to run my car this rich?
your thoughts?
if you are getting unburnt fuel coming out the exhaust then it is running rich. it should be tuned so that the afr's are around the 11.8 to 12.0:1 range. easiest way to see what its like is to stick it on a dyno and see what the afr's are like.
They are at that range.... however i still get a fair bit off black smoke coming from the exhaust
I've seen exotics running rich on occasion too.
gotta burn fuel to make power, stoichiometric is 14.7:1 so even at 12:1 you are putting more fuel in than can be completely burnt. unless it's excessively rich i would not worry.
My car is tuned rich (CRD) and when I was getting my new cat-back exhaust fitted yesterday the bloke said that normally when he pulls off an exhaust they have about 1-2mm of black crap lining the insides where as mine has 3-4mm which he said was 'too' rich.
It does blow plenty of black crap when I give it a belting which does become expensive but then I read threads of engines blowing up due to bad tuning and I sorta forget all about my engine running so rich.
Is it really blowing that much smoke? If its
I see in the headlights of a car behind a hase of smoke that one could consider a cloud. On the dyno and my other half strapping it past from the side of the road there is zero smoke.
How long has it been since your tuner calibrated his o2 sensor?
  • 3 months later...
Accel pump settings are set high on a PFC. The setting is in Milliseconds, so if you change to a larger injector they will be way to big making the problem worse. And "no" the accel pump settings are not scaled when you change the injector size settings in the PFC.
This setting can give you the big puff of smoke when you first accelerate and cover the back of your car with black crap.
This puff should clear quickly to no smoke on gentle acceleration providing the rest of the tune is good.
Mike
Mike
I tend to agree with this.. I've pulled dialed mine back a little past ~1/2 of the std value and still haven't experienced any drivability issues.
Just remember that TOO rich slowly glazes shit up and = death eventually. You need to find that comfortable medium.
My car is running a Wolf and off boost is an absolute dream on fuel (500km to a tank city driving), on boost it uses more, blows a bit of black smoke but nothing exessive and pulls hard, back off boost, comes back to good fuel economy. Its making 274.8rwhp too out of a fairly stock RB20DET (exhaust, Wolf, RB25 turbo and fmic) and the car is happy as.
your thoughts?
strange u get better fuel econemy running it harder, than putting around, my car is total opposite. a little black smoke is normal from a highly boosted engine, as where then it would be practical to run it a little richer.
seems hes running it richer, so it doesnt lean out up top. leaning out is bad , but of course running rich alot is bad also, over time, it will wear out ur rings.
maybe try a new tuner. should be able to rectify that with ur PFC i would imagine.. just gotta find someone who knows how to tune the pfc properly.
Well I have 700CC injectors and dialled my Accel pump setting to 1.5ms at 1000rpm down to 1ms at 3&4000rpm, much better and no black puff or cloud when I drive away. The setting is best felt by the driver on the road of course but with only gentle acceleration. The bit you're feeling for is the very initial push as you just open the throttle. Slaaming the throttle open especially at rpm under 3000 allows you to feel no change regardless of setting.
Zero them out and gradually increase them and you will see what I mean.
Mike
    • Pre-empting heat management  1. The Kraken manifold will be ceramic coated 2. Just purchased some peel and stick heat shielding stuff from car builders, I'll cover some of the firewall behind the dump and a little on the cam cover, this will be done prior to installation as I have ample room to get where I need to now before that realestate has more bits in the way, I'm also planning to modify the OEM heat shield to go back on, but that won't happen until after installation so I know where to hack it up, I'll also cover it with some some peel and stick to neaten it up after the hacking 3. As the dump is stainless with a flex joint coating isn't really a option, and wrapping isn't recommended for a stainless dump, so once it is installed I'll grab some shielding from car builders to cover the dump, as it has some stand off, it "shouldn't" cause any issues and it "should" just keep the radiant heat away from " melty engine bay stuff" Not for heat management, but I've grabbed some more black crinkle coat to paint all the shiny intake pipes, I'll pick the pipe work up prior to installation and use the paint booth and big oven at work to cure them, I'll then wrap them with some bubble wrap so they stay nice during installation
    • We're back on, gang - Our yearly pilgrimage south to our favourite cafe for an awesome brekkie! Yes, that's right... we're heading down to Austi Beach Cafe for a breakfast run through the Royal National Park! Before you drool over your phones/keyboards, here are the details: Date: Sunday 23rd February Meet Location: Loftus Oval Carpark, Royal National Park, Sutherland Meet Time: Meet at 7:00am for a 7:30am departure Destination: Austi Beach Cafe, 104 Lawrence Hargrave Drive, Austinmer Map: http://tinyurl.com/saunsw-austicruise  RSVP: If you are planning to sit and have breakfast with us, please let us know, either by posting in the event, or by messaging us direct so we can confirm numbers with the venue. Itinerary: We will meet at Loftus Oval Carpark which has plenty of room and is low car friendly. This is a quick turn into the Royal National Park and some nice roads and scenery. After Stanwell Tops we will turn off and head onto the awesome Sea Cliff Bridge. Following this it is a short trip to Austi Beach Cafe. There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • YO- have been searching and searching for an a31 chassis plug pinout, or someone who knows which wire is for tach.  ceffy was flooded past dash during a hurricane.  having an electrical gremlin appear. tach is wonky reading consistent with a short, and on occasion the right side of my speedo lighting will flicker just for a second then go back to normal.  if no pinout available does anyone know if the tach harness opens or branches anywhere behind the dash? im suspecting a possible root behind the radio as there are more shorts in that area on the accessory loop.
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
