It is a factory option
But you loose it when it gets complied, unless you swap your headlights for a standard set before compliance
That is what I am doing at the moment with another Stagea owner
I think you mean lose
i was told by nismo that you can re install them after compliance and they will give me instructions how to and send the original parts back to me with the car if i so request when mine goes to them for compliance .i spose time will tell
That's what they did to mine.
I can't believe how pathetic and yellow looking, standard lights are when you've gotten used to Xenon's.
Would be peeeerrrfect if the made the high beam spots xenon as well.
my question is why do they kill the xenon lights? especially when they are coming out as standard equip on bmw's and the like?
also does anyone else have the light height adjustment wheel down to the right of the steering wheel? and if so is it hooked up/does it do anything? as mine doesn't seem to do anything at all.
BTW guys,
i saw a thread in for sale section in the forum. The guy is selling HID kits for $350!! German components assembled in china though. 1 yr warranty. Do you guys know naything about this?
http://www.skylinesaustralia.com/forums/in...howtopic=125314
Also does our headlights uses H1 bulbs?
honestly, all aftermarket HID kits are shit. German parts assesembled in China ey. Let me tell you a story.
There is a company in Ballarat, it sells pots which are "made in australia". These pots are actually made in Malaysia, imported to australia and stickers put on them which say "made in australia"......think about it though.....the stickers ARE made in Australia....
the only way to get true HID's is to retrofit a headlight with OEM projectors. The standard headlamps if they are arnt designed to work with HID's just wont be good with HID's. I am sure S2's will be fine, but i am not sure I can say the same about S1's.
There is a really good website on my other computer, ill try and post it when i get that computer working again.
then how much for a oem projector do you know alex?
Mine has the light height adjuster and it does work - didn't think it did at first but one night tried it out again (out of boredom) and noticed they move up and down (subtle but they do move)
Would all S2 Stageas have had the Xenon's removed - would there be exceptions?
Cheers, Al
Cheers, Al
All Stagea's have to have the zenon's removed at time of compliance
The reason being they are not self leveling like the BMW's etc.
Which means the BMW lights should not shine in the eye's of on coming cars, but they still do!
The dial on the dash in the Stagea is designed for fine in cabin adjustment, for when the car has additional weight in the rear which causes the front end to rise, but unfortunitly this systems does not meet ADR's so the zenons have to be removed.
IAMSHE who is compling my car along with many other people's cars, has told me they have to cut the zenon bulbs wiring out and they are not re-usable.
So I am not sure how NIZMO do it.
Best way is to borrow a standard set for complinace and keep your zenon's, esp when they are approx $3000 new!
But you could get defected :O
cool thanks for explaining the reason behind the removal.
i was curious because i have a set of small triangular plugs floating around behind each headlight and was wondering if thats what they were for? they are 3pin plugs with the following coloured wiring
black
blue with white stripe
blue with red stripe
if anyone can tell me what they are for would be awesome?
the part number on the rear of the plug is 11016N6 if this helps?
Thanks Darrin for explaining that one. Another example of our design rules being rather unique, just like that dimmer switch for the dashboard lights that has saved so many lives :dry:
Just a shame the Xenon's had to go. I got my car from a dealer so no chance of saving them like you are doing
Cheers, Al
SO whats the easiest way at the end of the day for me to keep my OEM xenons?
I had them on my strawberry and I can't live with out them!!
DO I just tell the compliance workshop that you can take them out completely and i'll supply OEM headlights for it?
or if i was to borrow a standard set, would I have to do it behind the compliance joints back so to speak?
Cheers.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
