what unit was in there? if it was an aftermarket one hten the OEM plugs are still there. unclip and remove EVERYTHING that does not relate to the car. from there reuse the OEM patch plugs for your new one. solder and shrink the new stereo plug the the patch leads. done.
if you need accessories let me know.
Haha, I loved when I saw the first pic. Soldering and heat shrink is the best way to go. At least it has an inline fuse :P
Soldering + heatshrink is far cheaper than a set of crimpers, male crimp plugs and female crimp plugs. That's for sure.
as in the stock nissan adapter thats already there?
most likely thats what i'll be doing :)
yep remove all the crap and reuse that one. easier. though if you want to spend money I sell them.
