  • Replies 51
I think you can get turbo smart gates for like 600ish if you look around?
but then youd need a manifold suited to an external gate.
also, if you turbo is internally gated, im not sure if you can run an external gate, infact, i think no, you cant at all.
Guys.....sooooo sick of ppl gving other (not as knowledgeable) 'posters' sh*t about what they post about. Not everybody knows everything! is it so hard to tell the guy that he is getting ripped off and possibly steer him in the right direction rather than being smart as*es and laughin, wtf? Yeh sure he could go looking in the FI sections but who has time to search...besides, it was a simple question anyway!
1650 for a supplied and fitted wastegate....for starters, look who quoted that price...rigoli bros (LOL) - i wouldnt go within 100 miles of those dodgy c**ts and secondly, for another 1650 you could almost get a wicked GT3040 setup with the works
NISSAN SKYLINE R33 GTS-T 600HP TURBO KIT
INCLUDES:
GT 3040 600 HP BALL BEARING TURBOCHARGER
(.70 COMP & .82 EXH HOUSING), TIAL SPORTS 38MM EXTERNAL WASTEGATE, EXHAUST FLANGE, MODIFIED STANDARD MANIFOLD TO SUIT & BRAIDED OIL AND WATER LINES. about 4g's
I'd be going down that path if i were you...stuff just gettin a wastegate...go all out son and save your pennys haha.
regards, Lukas...
oh yeh and the reason WHY i called rigoli... was just to get a quote... so i know what im looking at... im gna keep looking around.. if its gna cost me more than $700-$800 to get what i want... il just save up n go for a turbo upgrade like u said.. but thanks for the info lukas.. :P
Gotta love the last 3 words in his post
INCLUDES:
Its about $2350 more than the $1650 you've already been quoted
lol..They dont see the difference.
Im like you...maybe not...but diddnt he want to spend less money...I think this is a dreamers thread..ahhhh!!
well.. i got a twin plate clutch, ecu, tein coilovers, im looking for some injectors atm.. and for diff well we will have to see if it wil handle such power... but either way.. its a long time b4 i start thinking of a turbvo upgrade... right now i want my ext wastegate/screamer pipe if i find one fitted for under $800 :)
Yeh nice one NISMOID. Your a smart one arnt ya. Ok yeh sure its like $2000 or whatever more that he was quoted but he was quoted for a freakin wastegate install....ive simply suggested that he saves up his money and get the actual parts that a wastegate is meant to support. Rami didnt actually state what his budget was so i am merely giving him some useful info which is more than u could offer. Whether he listens to it is up to him but i hav just gone down a similar path and its definatly worth saving for. Before you critisise other ppl's suggestions why dont you make a useful one yourself.
GOTTA LAUGH AT THE FACT THAT YOU THINK YOUR GODS GIFT TO SKYLINES LOL>
Laugh that one up NISMOID
Regards, Lukas
Yeh i can see the difference very clearly....get ripped off buying something that will do jack for his car or spending and saving his money more wisely and gettin a killer setup...gee i wonder which is the smarter approach?
Rami never actually said he wanted to spend less money...he simply wanted to know whether he was getting ripped off and what he should do...i hav given him my 2 cents.
Dreamers thread? 4g's isnt alot of money for something that is gonna make his car faster...the only "dreamer" in this thread was rigoli bros when they quoted such a rediculous price. They shouldnt need the money, they just gotta go out and steal one of our cars -----> C**TS
Regards, Lukas
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
