car has used a ton of fuel ever since i have owned it. tried everything including clean acc valve, clean afm, change o2 sensor and even driving like a grandma which is no fun.
recently my car had a engine problem and seemed like it ws loseing water so i droped it into ice to let them have a look. engine problem was 2 dead coil packs and water was cos i had no coolant left and the water was boiling away.
while the car was there they notice that my stock bov had a leak in the hose so the fixed that up and added all new spark plugs.
OMG i think the bov leak was the culprit. i used to get like 280-300 k's to a tank driving like a grandma and it always ued to idle at like 1200rpm. now im getting 400k's to a tank and a 800-1000rmp idle.
if you are suffering from poor fueld consuption i recomend you look at your bov and the piping connected to it cos this litle fix is going to save me like $20 a week in fuel.
woo
that is all
Edited by linxus40
https://www.sau.com.au/forums/topic/125127-poor-fuel-consumption-fixed/
I had an atmo bov when I got my car, and it sucked just as badly as it does now, with a factory BOV. No leaks, coils are changed (which fixed my missfire), new iridium plugs, afm cleaned etc etc etc....
No joy so far for me! =-[
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
