Guys,
An update on the prices for RE55 R compound tyres from Donnellans. Prices have gone up a bit from the prices listed in the old thread Here.
There's a couple of new sizes available too. Available from Donnellans in Box Hill... Oakleigh shop will match the price if it's closer to you.
New prices:
[ 18" ]
Bridgestone RE55 225/40/18 . . . . . . . $376 per tyre $395
Bridgestone RE55 245/40/18 . . . . . . . $383 per tyre $405
Bridgestone RE55 265/35/18 . . . . . . . $418 per tyre $440
Bridgestone RE55 285/30/18 . . . . . . . New Size $478
[ 17" ]
Bridgestone RE55 235/45/17 . . . . . . . $348 per tyre $355
Bridgestone RE55 235/40/17 . . . . . . . $351 per tyre $366
Bridgestone RE55 245/40/17 . . . . . . . New Size $386
Bridgestone RE55 255/40/17 . . . . . . . $375 per tyre $393
[ 16" ]
Bridgestone RE55 225/50/16 . . . . . . . New Size $290
Comparison of tread pattern between older Bridgestone 540s and current Bridgestone RE55:
Enjoy :wub:
Cheers.
  • Replies 62
I bought a new set only a month ago for 410 each at Box Hill.
Price went up early June. I called end of May and they were $412 fitted, then called late June $440 fitted.
Something to do with the price of oil was what I was told. Great excuse for retailers if you ask me.
I know some people run these on the street, but does the sidewall make it really stiff and rough on general roads?
Ive had some Falken Azenis RT215 semi comps, they were 16's, and it was a rougher ride than the street 18's on the same car. These were back on my Commodore.
Are the sidewalls stiff like the Falken track tyres, soft like road tyres, or inbetween?
I run them on the street & they exhibit the following characteristics:
They tram line like a bitch.
The stiff side walls give you a rough ride.
They make a shit load of noise, especially at 80 to 90km/h
They pick up every bit of shit on the road & fire it up into your wheel arches.
The don't last very long.
RE55's are like the Falkens, the major difference being you get proper grip to offset the cost & the other hassles.
With a proper set up & a clean track - 1.25 laterals gees of fun should be yours to have. :O
Edited by djr81
With a proper set up & a clean track - 1.25 laterals gees of fun should be yours to have. :)
You forgot to say - they go fast!
But yes the above is true. (Sigh) The price we pay to go 5sec quicker per lap.
The cost of rubber these days.
Bouncing higher and higher.... :) the god rubber
So ...My Tyres are going to cost more than the rims i ordered..
And steel has gone up in price too......
I just think it is all hype to make us pay more on the products they sell....like what was said on tv
I run a small business making office chairs and i have had no problems with price rises from my suppliers
We use steel and oil based products
This Sucks....We should all get together and have group buys for this...they are ripping us off
What next...our shoes are going to up in price by !5% because of the price of petrol :)
for those interested these tyres are in fact semi compound rubber, which is suitable for track usage. they are not recommended for normal street use. you can use them on the street but they react completely different to normal street radials. they are roadworthy and acceptable as far as ADR's and vicroads are concerned however.
the expected lifetime is somewhere around 8,000k's to 10,000ks for a set.
that would be normal street use i would expect, not sure how long they would last given full track usage. ie: not sure how many track days they would last
Well I put a set on approx 12 months ago. They have done a number of track days, approx 5000kms and are completely shagged.
If you are keen enough you can destroy a set in one track day.
The other thing that amuses me is how much of a difference some people expect them to make in a one minute lap. You may be lucky to pick up a couple of seconds over a good set of street tyres. Nothing more. Certainly not the 4 or 5 seconds over a minute lap that some people believe.
:thumbsup:
OK then...
Lets source a great tyre on road and track.....Set up a group pricing buy with the company
and then loose control....because it hasn't cost us much
Phillips Island - we tested with four people and they all improved by exactly five seconds straight away.
Sandown was like 4 seconds average
A decent steerer should be able to pull four seconds easy, and come close to five seconds even at a track like Winton.
I dropped 5 seconds off my time at Winton going from streets to semis... 1.43 to 1.38.... I did have a little bit more power, but i also had some brake issues, without the brake issues i think i would of had another second or so in there.... (on that day)
You would only classify the GT-SS as " a little more power". Your car is awesome :D
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
