Thats not exactly true Paul. In the wet I actually think they are better than standard street tyres - as long as there is a fair bit if tread left. And thats the hard part because with normal street driving you'll probably only get 5,000km's before they are shot.
But for exmple I remember last year at Calder (track - not drag) a WRX being 3s faster in the rain on RE55's than on his "good" street tyres. Same deal as when R comps are cold - they aren't as grippy as when they are hot but they are still more grippy than normal tyres.
As said - the biggest problem with R comps and street driving is value for money given the short life span.
Agree 100% on the above....last year at EC during the motorsport trip it absolutely pissed down with rivers across the track and standing water everywhere. I was simply staggered at the amount of grip the RE's gave me even when cold. Gadg was using RE's then tried his street tyres and had nowhere near the grip that he had with the semi's.
Biggest issue with them on the road is definitely the noise and the wear.
  • Replies 62
Just to add a little bit of comparison to this subject.
At EC last year in the wet my car (worn RE55's) was quicker than Gareth's (worn fat streets) when it was slightly damp or drizzling. But once it started to bucket down I simply couldn't keep up no matter how hard I tried. And believe me I tried (Got in trouble for drifting too) Was only a couple of seconds in it. But I think the degree of water makes a difference.
Steve give 'Gordon Leven Tyres' a call (they are at Emu Plains 5mins from Penrith) I was out there yesterday looking, from memory 245/40/17's were $390ish and 265/35/18's were $490ish (go up to 315/18's for 11inch rim) and the slicks were 250/17 at $490ish.
They also get used R's from all the NSW events from $80ish which will give you a couple of events worth of usage.
245/18 $465
Just by calling a few places around I got a couple quotes for 245/40/18 in the $410 to $415 range. So $465 souds a fair bit more than one needs to pay.
ps. Competition Tyres in Oakleigh quoted $410.
Edited by DavidM
245/18 $465
Where was the $465 quote from?
Prices for Re55's have increased significantly recently so the places that are quoting 'old' prices most likely have stock they bought at the old prices and probably want to move them.
Nothing wrong with that though :)
Wish I had a rubber factory............I can buy a car with wheels at those prices. :P
I agree don't run them on the road................dangerous when cold and wet.
Buy a set with rims for the track...................that is all
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
