got a hks type s oil cooler kit (sandwhich type) to suit all RB engines. its used and comes with all necessary fittings. selling as some bills have come up but otherwise i wouldve kept it... looking for a quick sale at $500+delivery. these units retail for about $900 or so.
PRICE DROP now $400 FIRM.
located in sydney..
https://www.sau.com.au/forums/topic/125129-hks-type-s-oil-cooler-kit/
from this site: http://www.importscene.com.au/prod542.htm
HKS Universal Oil Cooler - Type S
UNIVERSAL OIL COOLER KIT
There are two different types of oil cooler system. R (Replacement) TYPE is to relocate oil filter. Attachment of S (Sandwich) TYPE is inserted between engine block and oil filter.
Thermostat controls oil temperature
HKS Oil Cooler uses high efficient core. Thus it has thermostat to prevent oil viscosity friction due to over-cool (Except some vehicles). The thermostat responds quick to temperature. When oil temperature is not enough warm, it bypasses core to warm up engine quickly. If oil temperature exceeds thermostat working temperature, it flows oil to core to cool.
Thermostat closing start temperature 70?(±3?)
Thermostat closing complete temperature 80?(±3?)
* Applicable Meter fitting Oil Temp. Fitting M10xP1.0(R TYPE only), M12xP1.25 Oil Pressure Fitting PT1/8
Thermostat has relief function for safety
In case oil pressure has been unusually increased like core is damaged or oil line is stopped, oil is relieved from thermostat and it bypasses core to prevent engine failure and rupture of oil line.
Stainless mesh hose oil line for durability.
To connect surely, US Aeroquip stainless mesh hose and fitting, which are good function, durability and looking proofed by military usage, are used.
S-TYPE SPECIFIC INFORMATION
Attachment of HKS OIL COOLER S TYPE is inserted between oil filter and engine block. It is a high quality performance product. Mesh hose and fitting are Aeroquip. The attachment has sensor holes for oil temperature and pressure gauge.
* It does not relocate oil filter.
- Adopter thermo : M12xP1.25 (2 holes), PT1/8(1 hole)
UNIVERSAL OIL COOLER KIT S TYPE
Length of hose 3m
197×158.8×32, 12 rows (No.129)
- Core has been changed to popular size. (No. 012 --> No. 129)
* It is possible to install to vehicles which thread size of stock oil filter is 3/4-16UNF or M20×P=1.5. (Excluding some vehicles.)
sorry dunno to much about the specifics hope that helps.
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for ?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for  >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate modern almost all cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
    • Let's be wary though, if cranking is so far off, what else isn't set right? Are the dead times set right, voltage compensation etc?   It definitely sounds like it's cranking fuel issues, and holding flat to the floor is shutting them down, but I'm with Duncan that if nothing was changed in the ECU at all, and then this started, I'd be more thinking a leaking injector.   Do as Duncan said, drop the oil and make sure it's not full of fuel.
    • It actually means give it less throttle.
    • Yeah if the goal is to drive something then modifying a car is a bad idea.
    • Wowee! She looks like a major handful out there Pete!
