Is it just a standard turbo on a standard engine? Does anyone else habe this prob with the turbo on the same engine? Just thinking maybe your dump pipe might be causing some probs. I done work on my wastegate for my 2JZ because it is known to be much too small.
http://www.supraforums.com.au/forum/showth...light=wastegate
Edited by DennisRB30
Just take your turbo off and attack it with a die grinder :) Just dont grind the hole too big or it wont seal with the standard wategate flap!
I will be doing this to my HKS GT2535 as 14psi is the least i can run with the standard RB20det actuator and no boost controller.
Just take your turbo off and attack it with a die grinder :P Just dont grind the hole too big or it wont seal with the standard wategate flap!
What do you want to run less than 14psi for? :D
im doing it because the standard one does not flow out enough gas so its creating overboosting issues at high revs have wire the wastegate right open and drove car it still overboosts, my engine is no longer standard hence the increase in exhaust flow and my problem
I have done this on many highflowed turbos, and have had good results with gaining better boost control, open up the hole until there is about 1.5mm of metal for the flap to cantact, then blend the inside of the housing where the ehaust enters the turbo as much as possible without giong too thin in the wall, as this will make it more susceptible to cracking. I am a little concerned that it still overboosts with the gate wired open , as it really should hardly make any boost at all.
Dont be weak.. just go external gate :)
Before you go machining holes out just check that the dump pipe doesnt restrict the wastegate flap from opening fully as thats an easy fix!
Otherwise it will be related to the hole being too small and unable to vent the gas's at higher rpms due to more exhaust wheel flow.
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
