Hi all,
Upgraded my ECU and now have no need for the AFM; hence my old pod filter has become redundant as the adaptor does not bolt straight onto the inake pipe. As such, my Apexi Power Intake filter is now up for sale.
It's the older version (looks more like a cylinder than a mushroom pod) and comes with the Apexi adaptor that bolts onto your AFM. Also comes with the 4 bolts required to put it all together. Pod is in good condition but should be washed before putting on your vehicle, it's the dry type so you can wash it and dry it out!
Photos: (will try get photo of my one; but here's some off Google for now)
Chasing $50 for this filter; pickup is free, postage would be a bit more. Item is out of my car now and ready for dispatch - if anyone wants it, now's the time to snap it up!
Post up any interest please or PM me!
Thanks
Stan
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
    • Plug and play. Need a tune. It's a PowerFC, same as any other PFC, just not needing an AFM.
