Maybe we need one of those polls?
Those UK guys are mostly selecting 15W oils? Its a cold country, wouldn't they need the W viscosity to beas low as possible??
Theres more articles on Oil Viscosity too
http://auto.indiamart.com/auto-consumables...-viscosity.html
http://www.nordicgroup.us/oil.htm (Theres too much info here, seriously)
That second article says that W stands for Winter? and not Weight!
yes, oils reccomended in the UK is of little relevance here to our conditions. nismo boy, i would reccomend Motul 8100 10W40 for your 100K RB20DET.
Did you check the link? I find it interesting the commonly used visc is quite thick for such cold conditions where people are carking it left right and centre from their <30degree summer heat waves. lol
how can you say that the only difference between here and there is cold start after that the temp and condition the oil see are identical as both motors (here and US) will run at ~80deg and hp is hp no matter where you make it. The fact that even in cold countries like japan and england they run thicker oil was an eye opener and the fact the NISMO in japan recommend a 1060w was very interesting. As i think NISMO know how to build and run high performance motor.
pete
I dont think a standard engine running without an oil cooler is going to run the same oil temp with -5degrees ambient as it will with 40 degrees ambient. I could be wrong. Nismo reccomend their own brand of oil (of course) 10W60 for a GTR getting some track use I'm not aware of what they reccomend for an RB20DET. Nismo didn't build the RB20DET, nissan did and they reccomend a 7.5W30. Now given it's no longer anywhere near new I would say a 10W40 is a good choice. The wider the spread between the first number and second means the oil must contain a lot of additives. I'm no oil expert but I understand enough to know that that is not a good thing. I have used 10W60 without problem, but unless you are driving on track without an oil cooler (or on road getting very high temp) a 60 is not needed. It's just my opion though so no need to go nuts with the sarcasm about nismo knowing how to build a motor. Of course they do, and I've been to nismo omori factory in japan to see it with my own eyes. and like most companies they push their own product.
beer baron i think you should have a read of the uk thread as the guy OILMAN knowledge of oils is like Sydneykids knowledge of rb30's
the nissan oil is recommend for a std engine and road use
the nismo would be aimed a performance evironment and is more revalent to most uses in referrence to the weights used.
I would just say the imformation is of no use to us as the outside temp is slighty colder as the motors temp are all the same (thermostat control the major part of operating temp and 5 to 10deg outside temp will have little bearing on the oil)
Do remember the 7.5w30 is decided upon for power levels and economy reasons. When upping the power one really should also improve the film strength, higher visc and synth oils do this.
yes, hence the 10W40. :(
Hi Cubes , an interesting read . I'll have to do a search on Silkoline oils as its not one I'm familiar with . I know Just Jap sell Motul but not sure if its commonly available everywhere . It sounds like we could use a list of REAL synthetic engine oils so as not to get fudged by the marketing mongrels and their shh - its really mineral oil with 11 more herbs and spices ...
The Charade research octane lump has a gut full of 10-40 (I think) Magnatek because I always wanted to try something less viscous than 20W50 particularly in the winter . It is better for cold starts (rattles stop sooner) and no longer feels like its towing the car behind when I take off at 3 in the morning .
Sigh - I had thought that Castrol "synthetic" 10-60 was a real synthetic but that "Oilman" doesn't seem to think so or do I have that wrong ?
Actually I've been wondering a lot of late if lower viscosity oils with good "shear strength" can be used maybe we can run cooler thermostats to keep chamber / valve / bore / ring / piston temps down far enough to hold off detonation / allow a bit more advance under load .
Food for though cheers A .
There's quite a few oils available here in Adelaide
Apart from the usual there's:
ELF Synthetic
Nulon Synthetic :S
Fuchs (makers of Sikoline)
Might have to look in to the Sikoline stuff and see what its worth.
I really only want to pay $50 for 5ltrs, so really what ever fits the bill.
At the moment its Motul 8100 5w40 which is nice but I would prefer an oil with a little higher HTHS.
I'm almost tempted to see how the Mobil 1 15w50 runs as the running-in oil was fine (20w50) and I don't see temps below 10degree's so it should be fine. :)
http://www.mobil.com/Australia-English/Lub...il_1_15W-50.asp
http://www.castrol.com/liveassets/bp_inter...60_B1968_05.pdf
guys i have found my local Repco store sells the Motul 300v 15-50 100%ester oil for around $94 per 5 litres, so that will be my next oil to try in the GTR as its time for a synthetic (run in period complete).
Are you sure 5ltrs?
Motul 300v only comes in 4 and 2ltr bottles. So you must buy 6litres for a service one time then only 4 another.
Are you sure 5ltrs?
LOL you know i didn't even look to close at volume marking i just read the label and details on the oil to confirm it was the stuff the oilman(ukgtr forum) was talking about as i wasnt there to buy it ( at Repco) was helping a friend with the bosch part numbers for the z32afm and plug when i notice the motul.
And i will need more than a 2 and 4 litre bottle as my GTR run like 9 plus litres now with custom sump and oil cooler, so oil changes won't be cheap but if it looks after the internals it will be well worth it, as forged internals, nismo bearing and the works dont come cheap so it would be silly to skip on the oil.
Anyone running the 300v 15w50 in oz? thoughts etc?
pete
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
