Gday Folks,
Much to my dismay, whilst pulling my gearbox apart (RP71C) RB20DET - this little bullet shaped bearing was on my drop cloth after i rolled the box over. I have no idea where it came from. Ive been pretty careful to bag and tag and photograph everything but I have no idea where this little sucker came from! I think it might be to hold one of the selector rods in place when in gear but Ive accounted for all the ball bearings that do that!
Any help would be greatly appreciated!
JK
^^^ not any more..
As you're doing a R32 gearbox, you could try and get a hold of the R32 engine/repair manual.. it's the only one that has the gearbox details in it..
Actually.. just had a look through.. couldn't find it.. so there goes that idea.. there's an interlock ball.. and another one..
Edited by Links
Don't you just hate that.
My son and I were doing his clutch and found a single 4mm dia ball bearing on the drop sheet.
Had us absolute stuffed as there is NO-WHERE for it to go.
Rang a clutch EXpert and he thought it went in the flywheel dowel pin hole to balance the crank.
I thought bullshit as there is nothing to stop the ball from just falling out to get minced in the clutch plate.
Finally discovered my big socket set was now missing the ball from its square drive.
We'd used it and a heap of extensions to get at those bell housing top bolts.
    • By went out the old cluster completely died first it was the odo lcd then the gauges stopped working, Nissan said the board/chip went bad. I then ordered a used one off of amazon. I can transplant the speedo gauge itself I still have the old bad cluster. in fact I am trying to visually inspect to see any differences between the two. The back of the speedos themselves have a different number on the top one has a 5 the other has a 6 i believe printed at the top and the original motor looked a bit larger. On the board itself behind the speedo I saw a few differences looks like towards the bottom the my original board didn't have a resistor at R3. The SMD chip in the top right has some different numbers on it (maybe I can swap these) and the resistor at r16 might be different colors. So the new cluster came from a non turbo but it did have TCS the ebay seller said. hopefully these images will show:  New cluster broken cluster   I will try to transplant just the speedo first.
    • I'll match that and include 3 out of 4 of the speakers in a set of Alpine front splits.
    • *all RB25 s1 if I hadn't said yet, sorry guys haha
    • Yes, the speed sensors are quite different between NA and turbo. Completely different waveform. I'm surprised it's picking up any pulses at all if it is the wrong one. As to the original problem... "the instrument cluster went out". What does that mean? What died and how? Is there any hope that you could transplant teh speedo head from that into the new one?
