I'm having constant issues with getting my car to run properly. It's a S1 Rb25det in a S13. It feels like my car is pulling timing under any load over ~25% throttle. I've checked my coil packs and I sealed and taped them up already. I'm currently running without the factory boost solenoid. The wires for the solenoid are open and dangling in my engine bay right now. So that means I'm running whatever the wastegate is set to which I believe is 7psi. Does eliminating the boost solenoid from the system throw the ECU off and sets it in R&R mode? B/c I honestly feel like it's doing so.
I also have another issue with my fuel mixtures. I'm running a Walboro fuel pump on a completely stock fuel system. So I think I'm overloading my stock fuel regulator. I'm going to check fuel pressure tomorrow to see if it's playing any part in this mess.
Thanks for any tips.
If you have disconnected the solenoid and dont have another boost controller installed you will only run 5psi. the purpose of the solenoid is to bleed off some air to the wastegate actuator once you reach a certain rpm to allow the turbo to spin up to 7psi. when i first got my car i noticed that i was only running 5psi and was wondering what was going on. i found out that it was because the boost controller i had in it was completely closed off therefore only running at the wastegate actuator spring pressure of 5psi. lots of ppl think its has a 7psi spring but thats not true. I dont know if this will help much with your problem tho....
yeah as he said the stock wastegate is 5psi. if you are getting ricn and retard mode you will know about it. it is a sudden dead spot. and the is no way you would be able to get it on the stock wastegate unless you were running a monster turbo.
if your stock regulator is stuffed then the fuel pressure may be to much for it.
you say you have checked the coils, but have you checked the plugs? are you getting any stuttering when under load?
also if someone has played with the crank angle sensor and tried to adjust the timing then that may be part of the problem.
the only real way to test to see if it is running rich is on a dyno, unless you happen to have a wideband o2 sensor.
why do u think there is problems with mixtures
and the solenoid disconnected wont change much at all besides the boost
5psi would feel mighty slow all thou mine unplugged runs 8 so !
on that low of boost it would feel like the timing is out u could advance it so much more on low boost it would feel better then
    • That's it. Too rich for me. I'm out. If it does start to sell in pieces, I'll probably register an interest in the diff & axles, gearbox & tailshaft, and maybe the brakes.
    • I tried my best, well I see how it is though... It's time to be ruthless! I'll up my bid with a JVC sub and an amp to run it, 8 stainless steel drink coasters with a rubber backing, and a photo of Tom Cruise. Oh, I can increase the cash portion by 20 cents if that helps.
    • Or if it's grey, is it watery? Does it do it after you've been for like an hour long drive it will still do it, or just near the start of the trip? As GTS said, does it seem like oil (blue), water (white/grey) or fuel (black)? Sometimes the colour can be hard to see clearly too for what it is, as GTS says, what's it smell like?
    • I wonder if part of it has to do with when you've each bought the kits. I honestly have the feeling that the silicon joiners in the 2000s were actually better quality than most of what you can find these days. Even in the same brands. Everyone racing to the cheapest price while still trying to make profit means lower quality parts. For coolant, I personally would be going with rubber, OR, converting the radiator and engine to use the huge AN fittings hose for radiators.
    • If shift solenoid A is bad, that explains limp mode --- now you're in the same position as I mentioned previously, in that the next step is to confirm loom/wiring integrity from TCU to gearbox connector with a multimeter (the TCU cannot detect a broken wire, which can happen ..ie; rodent damage, loom rubbed through)...and then finally measure resistance (at the gearbox connector) for shift solenoid A ... ...once you confirm shift solenoid A is bad (open circuit, really low or greater than 40ohm resistance), then it's a job ; you have buy a complete solenoid set, get under the car and drop transmission oil pan, and remove valvebody assembly (the solenoids sit on top), replace solenoid set, and reassemble....it's not exactly a fun task, but readily doable.
