1jz head was designed by Yamaha and in my limited knowledge flows better than the RB25 head... but I am sure someone who knows abit more will give you some more specific flow rates
The 2JZ head is also desinged by Yamaha and flows better than a 1JZ by a fair margin. There was rumors going around that the 1JZ head was better but it has been proven to be bullshit.
http://www.supraforums.com/forum/showthread.php?t=339560
I remember Sydneykid stating there is not much difference between a RB25 and RB26 head flow wise it the attachments that make the difference vavles etc.
Not sure if this helps but here is a comparison between a 1jz vs rb25 with the same turbo. The RB make a fair bit more power, and the curve does not drop off as much as the 1jz this may suggest that the RB flows better but im no expert on the matter.
HKS PRO-S comparison
cheers
The 1JZ has very conservative cams which would explain the drop off in high RPM performance. Just wind the boost right up and the 1JZ will take it and out power the RB25. 1JZ747 runs mid 10's in a cressida with a stock 1JZ with stock cams but high boost. It makes an insane power level but at a shockingly low RPM. So the turbo comparison doesn't really prove much. Also your link does not seem to work?
Edited by DennisRB30
... and there's a completely stock internal RB25 that did 10's in an R33 Skyline with a manual. All 4 of the engines are pretty damn good from the factory, especially given how cheap you can get the younger siblings (1JZ, RB25) for.
How many passes did it do before it blew up? :P tic
The 1JZ is without question the best value for money engine you can buy. Costs half as much as a RB25. At the time of purchase my 2JZ cost less than a RB25 from the same importer which is why I picked it.
Uh hang on, why did you post a question if you already know all the answers?
That '25 is still going, there's a big thread about it somewhere on SAU.
No I do not know anything about the actual twin cam RB head flows. Just that the JZ are better value for money IMO. I even posted a link to JZ headflows. But I don't know how this compares to actual tests on RBs. Saying some engine made more power does not prove much since there are too many variables. I was hoping someone tested them side by side.
Great to hear that 10sec RB25 is still going. Top work from the people involved. Got a link to the thread by any chance?
RB26 heads flow more std and have higher potential than 2JZ heads. I know it's a pretty bold statement, and the difference isn't that great (~10cfm) and I'm not going to post scans of flow sheets... you'll just have to trust me on this :P Oddly enough WRX heads flow better than either. I think the stronger bottom end of the 2JZ far outweighs the slight flow advantage the RB26 head has, unless you "invest" alot of moolah into it... which is probably insignificant if you are extracting over 300cfm from the heads.
ive seen a 1jz running 14.5 af ratio's turn 406rwkw on 28 psi with stock engine. still running today.
All it had was a gt3540 82r with 38mm gate hks manifold exaust cooler 2j injectors and a safc.
He dont run it that high every day though lol
So doughboy you have actually seen comparisons of the heads done by the same flowbench operator at the same lifts? I know the JZs have slightly smaller valves, and they seem to have very small exhaust ports but the intake sides look very good.
My brother and I are fitting 2 subaru turbos on his 1JZ and are going to run over 20psi with just a SAFC, 2JZ injectors, fuel pump and pressure reg. Should be interesting :sick: Gona make sure AFR's are in the 12's though >_<
So is this a general info thread?
A Nissan vs Toyota thread?
I dont see much point being this is a Nissan based forum, so who really cares what the 1j or 2j do?
Info on RB head flows is related to skylines is it not? But yeah, I agree the thread did go a bit Nissan VS toyota.
Keep in mind this is a skyline forum any view will be biased. Both are good engines they all have pros and cons, different mods are needed at equal power lvls and its hard to say that one is better then another it all depends on the project and available $$$$
I believe the 1J NA head flows more than the 2J Turbo head. They did this to make it less of a tank on the road.
What if you had a 1J or 2J in your Skyline....I think I read correctly at the top where it says 'Skylines Australia' or is it just Skylines that have RB's fitted Australia?
Open your mind a bit.
I do have a 2JZ in my skyline :(
If its true about NA's flowing more its mainly in the exhaust ports because they are kept small on the turbo engines to give awesome turbo response.
The turbo on the other side was not a problem for me, even though it was my first engine conversion and my first attempt at making an exhaust. If anyone is worried about this and its the reason they don't want to fit a JZ itno their skyline PM me about it.
JZ Skylines FTW :D
I would love a R33 or 34 4 door with a 2JZ. I might do it one day. IMO, Nissan make better cars Toyota make better engines. Give credit where its due I say :yes: I am allowed to think skylines are an awesome car and JZs are an awesome engine. Combine the two for the ultimate I say :)
    • I know mentally you're set on the ATS clutch but honestly I'm a big fan of the Nismo Super Coppermix Twin. It's much cheaper and in some ways I think it's a better design for a street/circuit car.
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
