  • Replies 44
dude, see your boot lining, the grey bit behind the strut brace that hides the battery. is that the standard r33 boot lining piece? coz if it is, mine aint standard. and yours look much better.
https://www.sau.com.au/forums/topic/125209-sold/#findComment-2368671
  • 3 weeks later...
Guest
