Hey boys, firstly... look at the attatched pic....
dont tell me my R33 doesnt need lowering somthing shokkin....
I'm thinking of dropping in Lovell Super Lows with new Shocks all round......
does anyone have these springs in their R33? or is everyone now a days going for the Coil-overs?
I might just get a set for the rear and drop them in and see if it levels the whole car out because at the moment it looks like it leans to the front slightly.....
So if anyone could send me some pics of their R33 with some Lovell Super lows or whatever in it that would be great...
What does everyone think i should do?
Any advice appreciated...
Beef
https://www.sau.com.au/forums/topic/125220-lovell-super-lows-r33/
to tell you the truth...with the money you are going to spend on aftermarket shocks and springs and all the bits and peices needed.....you might as well buy coilovers and you can always change the height and most have camber features and more....
you wont have camber adjustment from coilovers, cos skylines have double wishbone suspension instead of macpherson strut.
get sydneykid's group buy on suspension
how much is your budget to lower your car?
well this is what i was thinking.... it already has Pedders Sports Rider suspension, i was going to ditch teh springs and get some lower ones....
i can get Lovell Super Lows front adn rears for $200, i know a guy.....
so what do you think about that idea?
Beef
post-26024-1152488385.jpgi have the lows not the super lows with 17 inch rims and i reckon mine sits nice
hey thast sits at a good height....., did u see my car? it looks a little high in the rear...
just for interest sake, i wonder how low the super lows take it.....?
Just to throw something else in the mix for you to think about, Lovells are a fantastic spring maker, BUT i think you MAY find that Lovells spring rate is a touch softer then standard. ??? Good for looks, but drivabillity and handling may be affected in a "not so good" way perhaps. get your guy to check that out as lovells probably wont tell you the rates.
Regards
R Dirty 3
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
