Hi Guys,
Just a question from a dumb blond... Ok what I am trying to do is rase the standard boost on a R33 GTS25T to a standard pressure of 9 psi but also retaing the standard boost controll that has a 2 psi jump to 11 psi.... What I am thinking of doing is to tap the actuator line and fit a boost bleed to give base boost of 9psi and still leave the standard controller in the set up that gives a 2 psi step up over 4.500 rpm...
anyone tryed this? if not do you think it will work ok. you guys been playing with these cars longer than me..Cheers Robyn
https://www.sau.com.au/forums/topic/125228-yet-another-boost-question/
main thing here is WHY ?
just remove th std staged boost and run 11psi all the time..
Hi, the idea is two fold 1) less boost for wet roads, reason being my partner is not a experenced driver yet and 2) fuel consumption around town...
Answers to first part of 1 & 2) throttle control.. Just because they are inexperienced doesn't mean they have to put their foot down all the time.. and 2psi isn't going to be too huge.. As for fuel consumption, well.. I wouldn't recommend a turbo and just drive off boost..
Answer for the 2nd part of question 1, you can do it.. I believe some of the guys tried it with the turbotech one, however found that it didn't work as exactly 2 psi and probably spiked a bit..
Personally if you have a stock turbo + stock ecu - run 10psi max.. running 11 will prob cause it to exceed the air flow threshold and Rich & Retard the engine..
Get a bleed valve and just run 9psi..
Edited by Links
i agree with the others. mutlistage boost is pointless, just run the safest boost you can on your system. use your pedal to control throttle. boost doesnt make a car use fuel, drive sideways or run into a wall. the driver and thorttle pedal do. just get some practice driving and youll be fine. if you arent cofident with the power, then simply dont floor it.
there is no other simple way to describe it
if you floor it
its going to bring on engine load
which will make more boost
which will make more air
which will make the engine work harder
dont floor it, it wont make boost
Personally I dont think 2 psi is going to make enough difference in either the fuel consumption or the power to worry about it
it will make a difference in power. if you have ever driven a r33 skyline still using the stock solenoid you can feel it when it jumps from 5psi to 7. also i have a dual stage boost controller set to 10 and 12psi and you can feel the difference.
also at WOT 2psi will make a difference to fuel consumption. there is more air going past the afm at the higher boost, so more fuel has to go in to keep the afr's in the same region.
yes I do realise that it will make an actual difference. sorry I forgot to say a noticable difference, or a worth while difference. meaning I doubt you would notice the huge amount of fuel you would be using running 11 psi as apose to the honda jazz like amount of fuel you will use when running 9 psi.
Basically Im with everyone else on here. I dont see why people bother with different boost settings. have your car tuned to a safe / powerful amount of boost and leave it at that. if you dont want to run high boost after that, dont put your foot down! but I for one cant imagine a time when I put my foot to the floor, let the revs go up and NOT want all the power of the engine. And for the fuel consumption, once again goes on the throttle control there, but you own a turbo performance car. It is never going to be good on fuel so when your driving around town, keep the revs down and dont put your foot to the floor. You will notice that the boost doesnt raise up if you keep the revs down, therefore there is your low boost setting!! Simple!!
Rhys
Rhys
Hi everyone. thank you for the advice I have built the set up I discribed the result is setting 1 standard boost settings 5/7 psi
2nd setting 8/10psi
3rd setting constant 12.5 psi
ok I can use the right foot to control the boost but this was a bit of a challenge for me, to do something I was told by a guy that couldn't be done... hahahaha
not only that but it looks nice with the little lights working...
so how exactly did you do it?
OK THE SET UP is basicly two systems in one the original boost controler is maintained the earth lead to this controller was cut and a diode placed in line to stop backfeed to the ECU A 2nd earth wire to a switch again with a diode inline to stop backfeed.. I then cut the main line to the wastegate inserted a T joint and ran a line to a electric shut of valve and then to a boost control bleed... so how it works ..nothing turned on standard boost 5/7 psi turn on the earthig switch to standard controler constant 7 psi boost ..Standard control switch off and the secondary controler on adds the standard boost 5/7 plus secondary boost added = 5+5 =10 and 7 +5=12 also with both switches on 7 psi original plus 5 psi secondary constant 12psi
see its simple
    • Give it 40psi and send it to the moon
    • I suspect 550s are on the large side for happy operation with a stock/Nistune RB20 ECU. The Hitachi ECU doesn't love short pulse width operation, and the RB20 doesn't need much fuel at idle. Big injectors can be unpleasant. This could be contributing.
    • Yeah, I still don't know why the idle speed control can't catch the falling RPMs. In the Consult logs I see the AAC duty cycle rising, but suddenly it goes lean and the engine stalls. Anyways, the relevance here is the DW 550cc injectors are probably the same. So if OP has similar issues I would be tempted to finger those injectors as problematic for whatever reason vs the ECU failing for some reason.
    • Yeah, sort of blurring two different things together, aren't we? I just meant O2 feedback closed loop. I used to have a 0-1V LCD meter on my dash, wired directly to the O2 sensor signal. So you could easily see what it was doing. Normal running it would flick back and forth nicely. Slow down to an idle and it would keep flicking, as the ECU tried to servo to maintain stoich, but it would slow down as each swing happened until it would stay at one end of the scale. As I said above, the sensor heater is not enough to keep it hot enough when there is also little heat in the exhaust flow. Give it a blip and it would start swinging again, then peter out again. Meanwhile, idle speed control would run just fine, because unrelated.
    • It's not even O2 feedback, it's just simply when the ECU sees the closed TPS signal for whatever reason the idle will start steadily dropping until the engine dies. With the TPS adjusted to not trigger closed TPS it will idle at some ridiculously high RPM and something like 6 degrees of timing. In the absence of getting eyes on it personally and a lot of quality time doing diagnostics I couldn't tell you what the real problem was but it was interesting nonetheless
