Hey guys
I was just wondering if anyone knew a cheap thing that i could hook up to my silvetop ecu so i can get all the data to show up onto my computer.
I would like to measure my AFR against my RPM and just stuff like that.
I was just wondering if there was something out there besides an aftermarket ecu
Thanks
What you want is a usb->consult cable and the conzult software, runs on any windows PC. Great for diagnostics and simulation, does contain not to be toyed with if you don't know what the ramifications are though...
Google nissan consult conzult
Thanks mate
Have you used this before?
Do you know where i can buy it?
And do you know where it plugs in?
Thanks
The plug connects to the consult port - in the R34 it's under the dash near the bonnet release.
I have the software courtesy of a mate, I believe he got it from the oz 300 forums
I have used it, another mate has used it for constant analysis after burning his own rom chip (for track fuel mappings etc). It's quite good for live and logged data
Sounds like its just what i am after
Do you know of any shops that stock the unit?
Thanks
I use my laptop with a USB consult cable... doesn't show AFR's though, you'd need a wideband sensor and some other hookup to show that. If you just want rich/lean, it will show that much.
Other alternative I was looking at is the Apexi i-moni. It's available from nengun, and plugs into your consult port... shows all that stuff. Pretty cool and a few hundred bucks.
Yeah I used my mate blatz usb cable on my car many times with great success.
It is by far a sweet bit of hardware and software.
U can even use it for fuel and ign map tracing etc. though this only works on the later R32 ecu model MEC R212 B. (RB20DET)
