Welcome to N/A Skyline section...
You will find most of infomation you need @ http://www.meggala.com/main.htm
If you can not able to find what you need please use this section as gain infomation or please share you ideas.
also Please use SEARCH button before you make a thred.
Thank you all :)
cheers
Joe
https://www.sau.com.au/forums/topic/12523-engine-brakes-wheels/
I know DBA have 4 stud disk rotors avaliable now :)
I don't know about the code of rotor. anyone know? if DBA released it?
for N/A Skylines you can use following Brake Pads
Bendix;
FRONT:DB 1308BS
Rear : DB 1144BS
Endless Pads
Front TD 148B
Rear TD136B
These were my old Endless pads, they are awesome stopping in any condition HOT or COLD. but it eats away Rotors and Creats bad Black Dust!
cheers
Joe
ve got a r33.
standard wheels are 205's R15
and basically measured 6.5inches wide
now, ive got 215's R17, and from the tape measure they should read 8 inchs across....yeh i found 17x8's in four stud and the wheels arent too ugly.
thing that stumped me was that, my stock and current wheels are the same width when physically lined up.
i realised the RIm on the stock was 6.5, and the tyre on it bulged out more then the rim itself, yeh the tyre was inflated properly....
that ends my stupid post for today.
There was only one ROH wheel that would fit my car apparently and it was one of those 3-piece wheels, which I don't particularly fancy.
Every shop said that the wheels wouldn't clear the calipers. I was after the Adrenalins but then I noticed everyone else already had them so it didn't matter...
Just replaced my brake pads with bendix premiums and machined the disc down to a shiny finish.
Compared to the pad when i first had the car, the bendix dont have a sudden and sharp bite, but seem to do an okay job so far. Im still in the process of wearing the pads in a bit. They smell a abit though.
They what now? I went to Bob Jane, first and last. When I started, the guy didnt know for sure, so he called ROH and asked.
Even checked on stock levels, and I had my wheels that day fitted. They miss the calipers by a clear inch in any direction.
Might pay to talk to the wheel guys direct if you can
  • 4 years later...
Hi guys and girls, i got a mint set of 4 stud tyres from Speed dreamz (not in operation anymore) for my R33 N/A. They came from tempe tyres in sysdney (i think) and they in turn got them from USA. Im positive that the stud pattern was created here in adelaide......or sydney as they stuffed up the alignment initially and said they had to go back for re-drilling. Whole process from asking to buy the rims to having them on my car (correctly) took about 2 months. So long story short if your happy to wait a while there is decent range out there if you just ask.
Kind regards, Evan
Woah back from 03!
i was going to get a set of deep Dish ones i liked from tempe but somebody said somewhere that they are of crap quality and are heavy.. anyone want to share their opinions? or a good japanese wheel site that do the 4 stud rims?
  • 1 month later...
hey i got n/a 33 and i was wondering what size are the brake rotors. just wanted to know beacuse there was a group buy on new rotors but i dont know how big my stockos are in the first place any help would be sweet
cheers
    • Do the R32s run high or low impedance injectors?
    • It may not feel like it to your wallet....but sounds like this was one of those "lucky you did it" rebuilds. Hopefully you have better luck this time
    • It's aftermarket. It also reeks of Honda Civic tryhard from 2003. But if you want one....then you want one.
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
