  • Replies 116
um extractors, 2.5" exhaust... RB20DE, absolutely no tuning, 4986km since the last service (oil and fluid changes), HKS airbox (not pod), running 95RON fuel... got me 86rwkw. :P
https://www.sau.com.au/forums/topic/12524-na-skyline-models/#findComment-232021
HAY WHAT ABOUT THE AUSSIE R31s! They ar N/a and tuff still ;)
They're faster than most of the same model coupes!
http://www.pbase.com/image/13398169
Prolly got 95 rwkw or so. Zorst, Pod and Extractors atm. Looking at the GTS2 model cam though. Got Koni's and King Springs all round and finally handles like all cars should!
Ummmm, GTS-R wing, GTSR front lip (needs 2 be painted n put on) GTS grille, GTS-X rims, and stereo.
Its my pride and joy! I love it!
https://www.sau.com.au/forums/topic/12524-na-skyline-models/#findComment-240465
R33 GTS25 with hicas, abs, airbag, lsd, sunroof and standard (boring) non type-m kit.
coby extractors, 2.5" hiflow cat, 2.5" HKS super drager exhaust from cat back, apexi super intake pod filter enclosed in UAS fibreglass box. running 16x7 and 16x8 bridgestone potenza rims off a silvia, with 205/50/16 and 225/50/16 yokohama A539 rubber front and rear respectively. it handles nicely and doesn't go too badly either (for a n/a).
https://www.sau.com.au/forums/topic/12524-na-skyline-models/#findComment-241688
Sweet info guys. Ill be getting a jap cat back in easter, maybe i can try and stretch the budget to get some local shop to make a nice set of extractors as well.
MearCat, are those trust extractors you have or only the cat back is made from trust? Is the trust system drony and loud?
https://www.sau.com.au/forums/topic/12524-na-skyline-models/#findComment-243274
R34 GT-V
I drive a R34 GT-V, basically a 34 GTT but without the turbo. I understand it was a special limited edition model of the R34 range - featured full GTT running gear, HICAS, uprated brakes, suspension etc but had the RB25DE Neo Strait 6 (as opposed to the Rb25DET in the GTT). It was also available in Bayside Blue (TV2) a color previously reserved for the GTR's (although it was possible to get Bayside Blue GTT's, these were later models that AFAIK were destined for markets outside Japan...)
For more info on the GT-V, see
http://www.nissan.co.jp/SKYLINE/0001GT_V/
Dave
https://www.sau.com.au/forums/topic/12524-na-skyline-models/#findComment-247351
Guest neoGT-25
THATS ONE HOT ASS CAR Demon Dave! :D
want to swap?
wait wait wait... im too tierd to understand this but, does your car have the RB25DET NEO from the GT/T without the turbo or is it the RB25DE NEO from the GT (like my engine)?
if its the RB25DET NEO from the GT/T w/o turbo it would be good to dyno the cars and see the difference... too bad your in Japan :D
nice colour tho... god i love R34's :( Isnt it a similer colour of the R33 400R blue?
meh... its a buitiful car anyhow... bye :(
https://www.sau.com.au/forums/topic/12524-na-skyline-models/#findComment-247411
Guest neoGT-25
Hey Nismodified, why are you buying a jap brand cat?
isent it cheaper to get a localy made item?
id love a A'PEXi exhaust system tho... but short on funds :D
Also... how many of us here with N/A lines have a jap exhaust compared to a localy made exhaust? also... what size are they? im getting a 2.25" front to back... is this a wise choise?
bye all :burnout:
https://www.sau.com.au/forums/topic/12524-na-skyline-models/#findComment-247413
Not sure about the specifics relating to the engines - I would imagine a RB25DE Neo Strait 6 is the same in my GT-V as it would be in a GT series, though I could be wrong. Power for the GT-V is rated around 200PS and it looks similar to other RB25DE engines I have seen...
Regarding exhausts, my car is fitted with a Kakimoto exhaust (thanks to the previous owner). Before I got the car I had never even heard the name Kakimoto. I have since heard that they are reputed to be very good, and the quality of the exhaust fitted to my car supports this.
https://www.sau.com.au/forums/topic/12524-na-skyline-models/#findComment-247506
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
