  • Replies 116
there's a difference between a layer of carbon fibre (most bonnets n stuff for looks in a car) and composite honeycomb carbon fibre used in masts and other spaceframes like bikes etc.
i think in the case of a carbon fibre layr on top of the alloy its just for looks.
  • 1 month later...
ok, i know this post is kinda cold now, but its sticky, so i thought i couold get away with re-opening it...
just a quick question about some older model skylines... pre R30 etc. One of my mates just picked up a '78 line with a 2.8 Turbo EFI motor in it. The body is in really good nik, and for 1200 bucks its heaps of fun :wassup: (not to mention fast) but i was just wondering if anyone had any pics of some tidy examples of the same cars so we could see where to go with this one. Was also wondering if some of you real buffs out there knew what the original engine was, coz im fairly sure it wasn't an L28ET !
cheers guys
phil
that would be the GC211 or KPGC211
The C211 series was released in August 1977 and, just like the C110 series, came in four versions. First of all, due to the fuel crisis and emissions regulations, the GT-R was missing and instead the Skyline 2000GT-ES (KGC211) marked the top-of-the-line now.
The latter came out in April 1980 and featured a new turbo-version of the L20, called the L20ET, with 140hp. This engine might have been less powerful than the GT-Rs, but in contrast to the S20, obeyed to emissions regulations and marked a new milestone in Skyline history: For the first time a turbo engine powered a Skyline.
The basic versions were called 1600TI and 1800TI now and featured L16 and L18 engines respectively, instead of the preceding "G" engines. The old 2000GT-X lost the X (and was now called the 2000GT), but kept an unchanged L20 engine, which still pumped out 130hp.
here's a model of one http://www.geocities.co.jp/MotorCity-Race/...galc211gtt2.htm
Garage GC211 in japanese http://www.geocities.co.jp/HeartLand-Cosmos/9175/
some pics here http://www.geocities.co.jp/HeartLand-Cosmo.../myjp/myjp.html
http://www.geocities.co.jp/HeartLand-Cosmo...n/mjp/tjp3.html
Basically the site has a huge DIY GC211 restoration section etc... use http://babelfish.altavista.com to translate it.
I'm not really a big fan of the GC211 more of the KPGC110... which is very remeniscant of a shelby mustang (aka elanor)
oh and if you bought a locally sold C210 this page has some info on it...
http://www.datsunworld.com/c210/c210.htm
but you need to change the tail lights to jap spec man...
thanks for the info guys !
the car is a fully imported 4 door model - still can't work out what the exact model is, coz it's missing the bumper (not a bad thing though, the big black one looks kinda weird...
ill let ya know how it turns out.
if you PM me the VIN number I can put it thru the Nissan Japan database n get you details on the car from production factory to cloth trim... I dunno if the software goes that far back though, but it couldn't hurt.
Guest
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
