Hi Guys,
I have a nice set of Enkei rims, 3 of them have mild to moderate gutter scuff, otherwise in perfect condition.
Does anyone know of any where in Sydney who would do a good job of machining them off?
Also would this affect the balance or strength of the wheel at all? I have been told this is not a problem as long as you don't machine to much off?
Any advice appreciated.
Thanks
Do you have any personal experience with them?
It's always hard to know where to go, especially when you get multiple recommendations.
Essentially I want to go to the best and get a bloody good job done.
Thanks
After calling up a few places about my rims, it seems that they don't grind off wheel material at all. Rather, some places putty it and others weld it then paint it.
Therefore, it shouldn't be any weaker. I'm actually contemplating whether to repair one of mine or not. I dunno, maybe I might just change wheels altogther.
Silver gts-t,
Sounds promising, do you know how they will fix your gutter rash, ie will they machine them?
MANWHOR3,
This the first I've heard of this, I spoke to a couple of places who advised they would machine them as long as they don't need to take to much off (Mine arn't really that bad).
Hard to know what to do, I'd like to keep them as their really nice rims.
Thanks
Silver gts-t,
MANWHOR3,
Thanks
depends how bad etc..
if they can smooth it out, they will, if not they may weld ontop and smooth over
how long is a piece of string?... it always depends on the amount of work they have to do.... simple gutter rash shouldn't cost more than around 80 bucks a wheel and they'll look like new... you can also get them just sanded back, it's cheaper but yr better off getting the clear coating as well.
  • 1 year later...
Siddr20: Greg aka MagMan done very good job and his price is reasonable
I had my rims fixed by him.. he can fix any sort of damages.. like small gutter rush to buckle or cracks.. he can do either weld, mechine or polish and balance the rim to perfection!
I knew him since I've got my first car and put the rush on my very first mag wheels!! and now over 10 years I still go back there when I need rims fixed! (even now I live near Newcastle)
only problem is.. he very busy and only works by himself, sometime it could take over 2-3 weeks before he can start working on ur rims. so, better call him before drop them off !
hope this help
Ford
Edited by subie
I know a guy he did mine, I thought that they were screwed as the mags were that bad they were given to me, he fixed them up a treat, I don't think he'll fix buckled rims though. He also does paint repairs and plastic welding etc etc.
Contact Brian operating under Unek paint repairs 0145333330.
Cheers.
hope this help
Ford
Would you have his number and roughly how much did he charge?
Also where is he located?
thanks dude
Cheers.
Cool will give him a call as well..
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
