hey fellas,
i'm buying a modified r32 gtst soon and was wondering the requirements needed to pass for a RWC?
Engine Mods were: Custom Garrett 500HP Ball Bearing Turbo, Braided Oil and Water lines, Bosch 044 Fuel Pump, Bosch 555cc injectors, Custom Fuel Rail, Malpassi Rising Rate fuel regulator, HKS Air Pod, HKS Heavy duty actuator Valve, 3inch turbo back exhaust with Dual chamber dump pipe, Microtech LT10s computer
Apexi AVCR, stainless steel intake pipe, Hybrid Front mount intercooler, Catch Can, Exedy Heavy duty organic clutch, Lightened flywheel
Other mods: Phillips XENON headlight kit, Sony XPLOD Head Unit, Blitz Turbo Timer, Blitz Boost Gauge, Razo Gear Knob, Nismo Short Shift Kit, Momo Steering Wheel, new tyres
What modifications do they usually check for a RWC, how long does it take for the checkup and also the price to get a RWC done?
thanks
https://www.sau.com.au/forums/topic/125264-requirements-for-a-rwc/
From what I can see, illegal modifications are:
Pod filter + FMIC combo, aftermarket ECU, boost controller, catch can if it vents to atmosphere.
I'll assume the Philips headlight kit complies to ADR standards so that will pass.
The boost guage might be a problem if it's mounted on the A-pillar, so will the steering wheel if any part of it is highly reflective (ie. chrome) and distracts your vision (ie. glare). Also make sure because you don't have the stock gear stick knob, that you have a sticker to indicate your gear patterns.
Apart from checking the basics such as lights, wipers, etc, they will usually check your suspension and steering bushes under the car as well, so make sure steering boots or whatever aren't cracked and so forth. They will also check for exhaust leaks and if your engine and gearbox mounts are still in good condition.
Someone else might have more information for you.
You'd be better off talking to the place thats going to do your WRC
there is such a large inconsistency with the application of the regulations that one place will pass things another wont, but pick on stuff that really shouldnt be
hey fellas,
Strictly speaking whoever you are buying it from is supposed to supply the RWC. This can be a negotiation point, but at least make the purchase conditional on an initial RWC inspection.
i had to do organise the rwc on my r33 when i got it. it failed the first time for:
wiper blades
split muffler
rear seat not secure
compliance plate covered
wing not secure
and i have on it
atmo bov
dual stage boost controller
2 guages on a pillar
pod and fmic combo
depend where you take it really...
thanks for that guys, appreciate it.
Hey there, >_<
A roadworthy is a test of the cars ability to be driven safely...
So...brakes,tyres,wipers,lights,seat belts ,windsreen,horn,shocks,excessive oils leaks,holes in the muffler or smoke out of the rear end are basically what they look at....its not an epa test
I am a mech, and work at a roady specialist.
Most things are checked to be secured and present; ie emissions gear to appear to be present; cat, stovepipe, charcoal canister etc.
All loose items; sub, stereo etc, are to be secure, as it the battery.
They largely look at leaks, bushes, ball joints, unis, tyres, brake pads, disc rotor thickness etc.
thanks for the replies everyone. I was also wondering an estimate of how much a RWC will set me back, considering the mods?
Also, does anyone know of a mechanic that can take a look at the car on wednesday, around the Lilydale area?
cheers, miguel
Edited by Race Bred
cheers, miguel
The costs all depend on all the above items mentioned and there costs...ie tyres brakes windscreen etc might all need to be replaced
After the roadworthy you get a paper listing your problems and off you go to fix them
The cost of the roadworthy if i recall is about $70 but the cost to you depend on all the faults.
I believe you are given two weeks to fix them and return back to the place to re-inspect and stamp
the paper work.
Once the dates expire you need to pay the $70 again.
You might be pleasently surprised or dumbfounded on the faults and the money you need to spend to get it roadworthy.
Good Luck
Edited by 700HP-GTR33
