Race Bred Posted July 7, 2006 Share Posted July 7, 2006 hey fellas, i'm buying a modified r32 gtst soon and was wondering the requirements needed to pass for a RWC? Engine Mods were: Custom Garrett 500HP Ball Bearing Turbo, Braided Oil and Water lines, Bosch 044 Fuel Pump, Bosch 555cc injectors, Custom Fuel Rail, Malpassi Rising Rate fuel regulator, HKS Air Pod, HKS Heavy duty actuator Valve, 3inch turbo back exhaust with Dual chamber dump pipe, Microtech LT10s computer Apexi AVCR, stainless steel intake pipe, Hybrid Front mount intercooler, Catch Can, Exedy Heavy duty organic clutch, Lightened flywheel Other mods: Phillips XENON headlight kit, Sony XPLOD Head Unit, Blitz Turbo Timer, Blitz Boost Gauge, Razo Gear Knob, Nismo Short Shift Kit, Momo Steering Wheel, new tyres What modifications do they usually check for a RWC, how long does it take for the checkup and also the price to get a RWC done? thanks Link to comment https://www.sau.com.au/forums/topic/125264-requirements-for-a-rwc/ Share on other sites More sharing options...
ToF Posted July 7, 2006 Share Posted July 7, 2006 From what I can see, illegal modifications are: Pod filter + FMIC combo, aftermarket ECU, boost controller, catch can if it vents to atmosphere. I'll assume the Philips headlight kit complies to ADR standards so that will pass. The boost guage might be a problem if it's mounted on the A-pillar, so will the steering wheel if any part of it is highly reflective (ie. chrome) and distracts your vision (ie. glare). Also make sure because you don't have the stock gear stick knob, that you have a sticker to indicate your gear patterns. Apart from checking the basics such as lights, wipers, etc, they will usually check your suspension and steering bushes under the car as well, so make sure steering boots or whatever aren't cracked and so forth. They will also check for exhaust leaks and if your engine and gearbox mounts are still in good condition. Someone else might have more information for you. Link to comment https://www.sau.com.au/forums/topic/125264-requirements-for-a-rwc/#findComment-2313558 Share on other sites More sharing options...
R31Nismoid Posted July 7, 2006 Share Posted July 7, 2006 You'd be better off talking to the place thats going to do your WRC there is such a large inconsistency with the application of the regulations that one place will pass things another wont, but pick on stuff that really shouldnt be Link to comment https://www.sau.com.au/forums/topic/125264-requirements-for-a-rwc/#findComment-2313572 Share on other sites More sharing options...
Race Bred Posted July 7, 2006 Author Share Posted July 7, 2006 thanks for that guys, appreciate it. Link to comment https://www.sau.com.au/forums/topic/125264-requirements-for-a-rwc/#findComment-2313579 Share on other sites More sharing options...
ToF Posted July 7, 2006 Share Posted July 7, 2006 I hope you know someone who owns a workshop so you don't have to take too much stuff off... let simple stuff slide Link to comment https://www.sau.com.au/forums/topic/125264-requirements-for-a-rwc/#findComment-2313588 Share on other sites More sharing options...
Race Bred Posted July 7, 2006 Author Share Posted July 7, 2006 that's a problem i have. Link to comment https://www.sau.com.au/forums/topic/125264-requirements-for-a-rwc/#findComment-2313599 Share on other sites More sharing options...
R31Nismoid Posted July 7, 2006 Share Posted July 7, 2006 Are you buying this car or selling it? either way, you gotta know someone to get something with that many mods to pass. The ECU is the main one really. Although ive never had mine checked for a RWC Link to comment https://www.sau.com.au/forums/topic/125264-requirements-for-a-rwc/#findComment-2313631 Share on other sites More sharing options...
SteveL Posted July 7, 2006 Share Posted July 7, 2006 hey fellas, i'm buying a modified r32 gtst soon and was wondering the requirements needed to pass for a RWC? Strictly speaking whoever you are buying it from is supposed to supply the RWC. This can be a negotiation point, but at least make the purchase conditional on an initial RWC inspection. Link to comment https://www.sau.com.au/forums/topic/125264-requirements-for-a-rwc/#findComment-2313653 Share on other sites More sharing options...
VB- Posted July 7, 2006 Share Posted July 7, 2006 yeh get the previous owner to do it if possible. you might not know anyone who can help you in this situation, but he might Link to comment https://www.sau.com.au/forums/topic/125264-requirements-for-a-rwc/#findComment-2313699 Share on other sites More sharing options...
C_DawG Posted July 8, 2006 Share Posted July 8, 2006 Make your appointment on a Friday arvo, the tester will be that desperate to get out and have a beer he will pass anything. Link to comment https://www.sau.com.au/forums/topic/125264-requirements-for-a-rwc/#findComment-2314246 Share on other sites More sharing options...
Freddy Kruger Posted July 8, 2006 Share Posted July 8, 2006 i had to do organise the rwc on my r33 when i got it. it failed the first time for: wiper blades split muffler rear seat not secure compliance plate covered wing not secure and i have on it atmo bov dual stage boost controller 2 guages on a pillar pod and fmic combo depend where you take it really... Link to comment https://www.sau.com.au/forums/topic/125264-requirements-for-a-rwc/#findComment-2314260 Share on other sites More sharing options...
700HP-GTR33 Posted July 8, 2006 Share Posted July 8, 2006 thanks for that guys, appreciate it. Hey there, A roadworthy is a test of the cars ability to be driven safely... So...brakes,tyres,wipers,lights,seat belts ,windsreen,horn,shocks,excessive oils leaks,holes in the muffler or smoke out of the rear end are basically what they look at....its not an epa test Link to comment https://www.sau.com.au/forums/topic/125264-requirements-for-a-rwc/#findComment-2314631 Share on other sites More sharing options...
R31Nismoid Posted July 8, 2006 Share Posted July 8, 2006 A car is not deemed to be "roadworthy" if it does not pass emission laws. Hence EPA should have an effect, but some mechanics turn a blind eye Link to comment https://www.sau.com.au/forums/topic/125264-requirements-for-a-rwc/#findComment-2314644 Share on other sites More sharing options...
Mulkers Posted July 9, 2006 Share Posted July 9, 2006 I am a mech, and work at a roady specialist. Most things are checked to be secured and present; ie emissions gear to appear to be present; cat, stovepipe, charcoal canister etc. All loose items; sub, stereo etc, are to be secure, as it the battery. They largely look at leaks, bushes, ball joints, unis, tyres, brake pads, disc rotor thickness etc. Link to comment https://www.sau.com.au/forums/topic/125264-requirements-for-a-rwc/#findComment-2315307 Share on other sites More sharing options...
Race Bred Posted July 9, 2006 Author Share Posted July 9, 2006 (edited) thanks for the replies everyone. I was also wondering an estimate of how much a RWC will set me back, considering the mods? Also, does anyone know of a mechanic that can take a look at the car on wednesday, around the Lilydale area? cheers, miguel Edited July 9, 2006 by Race Bred Link to comment https://www.sau.com.au/forums/topic/125264-requirements-for-a-rwc/#findComment-2316662 Share on other sites More sharing options...
700HP-GTR33 Posted July 9, 2006 Share Posted July 9, 2006 (edited) thanks for the replies everyone. I was also wondering an estimate of how much a RWC will set me back, considering the mods?Also, does anyone know of a mechanic that can take a look at the car on wednesday, around the Lilydale area? cheers, miguel The costs all depend on all the above items mentioned and there costs...ie tyres brakes windscreen etc might all need to be replaced After the roadworthy you get a paper listing your problems and off you go to fix them The cost of the roadworthy if i recall is about $70 but the cost to you depend on all the faults. I believe you are given two weeks to fix them and return back to the place to re-inspect and stamp the paper work. Once the dates expire you need to pay the $70 again. You might be pleasently surprised or dumbfounded on the faults and the money you need to spend to get it roadworthy. Good Luck Edited July 9, 2006 by 700HP-GTR33 Link to comment https://www.sau.com.au/forums/topic/125264-requirements-for-a-rwc/#findComment-2316777 Share on other sites More sharing options...
