Well guys/gals - its finally here! My turbo back exhaust is complete! BATMBL s/steel front/dump pipe, large 3 inch catco cat and Trust PE2 cat back! About $1400 odd, for the whole lot including installation and it sounds great! (well to me anyway) Got RE Customs in Springvale (Vic) to install it - and yeah, it makes a whole lot of difference. Havent really taken the car for a good spin yet, due to the rain, but it feels a lot better to drive. Its extremely quiet too, until about 4000 revs - then it makes a howling sorta sound.
The overall installation was pretty much spot on - everything fitted perfectly according to Ray Evans. Took it in today at around 11am, was finished by about 3 (including my 5000klm service).
Will post up pics after I washed the car.
(Michael - batmbl - thanks heaps bud, was a great buy the dump/front pip and cat :P )
Edited by emsta2003
https://www.sau.com.au/forums/topic/125272-new-exhaust-updated-with-pics/
  • 3 weeks later...
Lovely exhaust... got one on my 34 :woot: You want it to sound even better? Get them to cut out the centre muffler (resonator) from the PE2 and replace it with 3" straight pipe... done that to a few cars now (all with PE2s) and they absolutely roar after!
Thanks bud - I am quite happy with the way it sounds, as it doesnt attract the cops - how much louder would it be without the resonator?
There are reasons for doing it though; not all for the sound...
1) The resonator (in my case) was hitting the uni-joint (???) after the split front/dump installation so it had to be removed to stop the contact.
2) The resonator on the PE2 is not straight; if you look at the entry and exit; it's actually off-centre. This can restrict flow... replacing it with a straight pipe will solve this.
stan, any resonators you cut off trust PE2s I would be more than happy to take off your hands. :woot: this goes for anyone else in sydney too.
how many have you got there? lol
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
