2.5 models will be able to be landed for the same price as v35 sedans low 20's it will be more expensive for the 3.5 6 speed manuals as alex says probably between 30 to 40k
it would make a great family cruiser me thinks my grandparents are looking at one
have a go at the camber on those rear wheels... drift camber. a 5k launch would leave to blck mark for 30m - but each one would be about 2 inches wide... and youd be seein more canvas than a circus tent.
I am looking at M35's now but the manual ones will end up costing more around the 40-50 mark compared to a 260rs being 30-40 (on road for both)
M35 is definatly hotter and id get free compliance here in Melbourne, but still...
My mate might bring in a Legnum and cop free compliance too from a workshop ive spoken to.
i seond cruiseliner to go for a 260rs anyday over the m35. You have to remember M35 is a NA engine same engine that the Z uses. 3.5ltr drinks a bit as well. And theres not much mod you can do to a M35 other than the nismo tunes one. Apprently theres M35 in Oz already in carsales or carpoint. I saw it when i was searching for a 260rs. From memory its a gold color one selling at 50k.
Yes it does come out in a single turbo VQ25DET with a 6sp manual trans, mmMMmmMMmmMMmmm not bad!
I wonder if AUTech are going to make a 260/M35 version....? With all the bits bolting on to the M35 that bolt onto a 300ZX I doubt it would be hard to whack another turbo on and put a tough drivetrain in.....
huhuhuhu!!!!!! I can feel 360Rs in the air!!!
So the only way to get one of these into the country at the moment is through a private import right?
Or has someone got a low volume licence for them?
Considering that one in NZ is only about $13000 AUD you must be able to get a manual 2.5T for under 20K So landed that would be about $25K right???
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
