Guest nizmoboi
Hey im trying to chase up a front edge or 400R front spoiler for my R33, anywere around brizzy. So far ive been quoted $800 for the front edge at arespeed. And then some guy off da street came up to me and told me he can get me a 400R front spoiler for $400!!! sounded a bit sus to me.... So if anyone knows were and how much these kits are can they tell me ..cheers.:burnout:
https://www.sau.com.au/forums/topic/12530-400r-or-front-edge-kit/
I don't know if there is a 400R front spoiler but I do know that there is a 400R front bar.... for an unpainted one, that sounds about the right price. Just make sure that you getthe one that suits your car, I bought one for mine and got it painted and all, then when I tried to put it on, it didn't fit because it was made for an R33 Series 1 and I have an R33 Series 2. Now I'm stuck with it, and will probably have to go back to the paint shop to get the bar seriously modified :)
Did you check the material on that $800 one? If the material are pretty strong and thick then you got a good quality one. Some cheaper copies are way too thin, make sure the $400 one is not made of the thinner material that will flap around and crack at the slightest bump.
hey NO_RSPECT,
the bummer thing about it is that I got it painted before I fitted it, don't know what I was thinking.....did they juts chop the whole top lip off and remould it to fit the SII?I was just thinking of doing it with some filler, it's just the lights that annoy me cos they don't line up, they look pointy compared to the rest of the bar.... have you got any pics of it? can you email it to me at r33_sidewayz@yahoo.com.au
any help would be much appreciated. :D
cheers mate...
Des.
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
