Today i decided to change my spark plugs.
First time ever i have done this. Ive only owend the skyline for 3weeks now and learning slowly.
WOW spark plugs are easy to change!!! Im so proud of myself.
Never will i let a mechanic change them and charge a fortune.
So i decided to get the NGK Iridium plugs since ive heard ppl rave about them but there cirtainly not cheap but alot more economical than letting any mechanic change them.
So heres what i pulled out, do many ppls spark plugs look like this when they pull them out???
And while i had everything off i decided to paint the rocker cover and sway bar...what do u guys think?
https://www.sau.com.au/forums/topic/125333-bit-of-fun-for-today/
Wow those old plugs look f**ked, why is there so much rust. :
Good stuff for doing it yourself!
I hope you used heat proof paint for the coilpack covers otherwise it will just peel. Also FYI that bar you painted is not a sway bar, it is called a strut tower brace.
Edited by ToF
well done on your first plug change.
now go out and take the coils cover back off. all they do it hold heat in and cause the coils to cook. and personally i wouldn't have used iridiums. my car had iridiums in it when i bought it. i pulled them out when they were less than 20,000 kms old and they were screwed. i put in ngk coppers. less than $4 each and just replace them every time i do a service. works out cheaper to spend $25 every 10,000k's than $120 every 20,000k's.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
