Well the topic pretty much says it all....Started taking off turbo gear and found it abit hard to get to those middle bolts/nuts what ever that bolt the manifolds onto the head.
So whats the best way, i know george has done it probally afew times :sick: HELP Me pwease >_<
So whats the best way, i know george has done it probally afew times :yes: HELP Me pwease :D
Fairly easy. you need to remove the small inpsection covers on the intake manifold. Then you can see the top two exhasut manifold bolt heads. Most of the time you can fumble around and find the others. Ive had mine off so many times. Haha. Make sure you have a good socket set.
I needed like a 6inch extension with a 3 inch extension attached.
It is a pain in the ass. Get that heat shield off from the inlet manifold and it makes things easier. U just gotta kinda feel around with ur fingers until u feel the bolts, then get ur socket in there while fingers on bolt so u get a feeling of where the socket should go.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
