Well the topic pretty much says it all....Started taking off turbo gear and found it abit hard to get to those middle bolts/nuts what ever that bolt the manifolds onto the head.
So whats the best way, i know george has done it probally afew times :sick: HELP Me pwease >_<
So whats the best way, i know george has done it probally afew times :yes: HELP Me pwease :D
Fairly easy. you need to remove the small inpsection covers on the intake manifold. Then you can see the top two exhasut manifold bolt heads. Most of the time you can fumble around and find the others. Ive had mine off so many times. Haha. Make sure you have a good socket set.
I needed like a 6inch extension with a 3 inch extension attached.
It is a pain in the ass. Get that heat shield off from the inlet manifold and it makes things easier. U just gotta kinda feel around with ur fingers until u feel the bolts, then get ur socket in there while fingers on bolt so u get a feeling of where the socket should go.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
