gday
have hr31 coupe.
have found z31 5 stud rear hubs (direct swap for the shitty hr31 4 studs)
anyway, need to get some bearings for them. got to be z31 bearings (the hr31 bearings pose problems with fitting the hubs etc)
nissan spare parts were no help, nor were automotive shops that i went to
nissan spare parts told me not to come back until i had a z31 vin etc
unfortunately i dont know anyone with a z31 with irs rear end (gotta be irs, not live)
anyway, this picture from FAST shows some numbers
failing this, i'm considering giving the hubs to a workshop to source and put on the bearings for me
any advice re part #'sm or suggestions for workshops in sydney (preferably south west area) that can do this for me, would be much appreciated
cheers, mark
Edited by 88silhouette
https://www.sau.com.au/forums/topic/125352-help-re-hub-bearings/
Well according to FAST the PN's for the bearings are:
Outer: 43215-01P00, which has been superceded by 43215-19P00
Inner: 43210-21000
These are for a Z31 turbo, whether they will fit your R31 arms is another matter.....IOW, don't blame me.
Suggest you take these PN's to a bearing specialist as they have catalogues that cross-reference manufacturers spare part number with standard bearing ID's.
Inner: 43210-21000
cheers for that mate
anyone recommend bearings specialist for the job in sydney?
just FYI for steveL here ....... Z31 5stud rear hubs have been used in HR31s for MANY a conversion........ the R31house machined hubs which are about 750 a pair ..... hands down make the Z31 a cheaper option if u can find the c**ts.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
