i just got wide front fenders on my gtr,
i need to run 30mm wide spacers to make my 17x9+21off wheels to fit the gap
my question is
what are the disadvantage of running such a huge spacers in the front ?
i'll be running one with a longer stud.
will the hub wear out? will i get slow steering responds ?
This moves the tyre contact patch outwards 30 mm, which means;
Tramlining, pretty bad I would say
Premature wheel bearing wear
Heavy steering
Hence steering linkage wear
And steering rack wear
Premature tyre wear
Increased loading on the radius rods due to the increased leverage
Leading to increase radius rod bush wear
Or if you have spherical bearings with adjustable radius rods, perhaps bearing failure
Premature wear of the upper inner and outer conrol arm bushes
Premature wear of the lower inner control arm bush
Premature wear of the lower outer ball joint
That's about it for a start.
:D cheers :yes:
PS; with the power output your engine is going to have, the tramlining will be extreme
Heavy steering
Premature tyre wear
:) cheers :D
how would these things not happen if the offset of the wheels were 0 and stuck out further? Or would then happen regardless in puttng a wider wheel with lower offset on the front
sydneykid, that's quite interesting what you said above. I was just wondering whether the same applies to using a different offset wheel too?
e.g. stock r32 gtr wheels are 16x8 +30. If I ran a 16x8 0 offset, that effectively brings the wheels out 3 cm right?
Will this have the same effect?
The car might tramline, but at least it won't look like a Tram with wheels hidden under the guards :)
As for the other questions, are you guys seriously asking if a wheel with a certain offset is different to
a wheel spacer combo with the same offset?
If one person is 6 foot in high heels and one is six feet with bare feet will they both hit their head on a 5'10 doorway?
Edited by Laurence
It is the same thing. Adding wheel spacers effectively changes the wheel offset.
Legend has it that GT-R's don't really like having this sort of thing done to them...
Edited by djr81
The car might tramline, but at least it won't look like a Tram with wheels hidden under the guards :O
Spacers aren't the answer, skinny front wheels hanging out side the rear track looks almost as bad.
A better answer is 10.5" wide wheels with 0 offset, making them 21 mm further out and 17 mm further in.
That will give a barely discernable increase in tramlining.
You will need to do a little inner guard tweaking, nothing major.
Obviously that's all round, so will need to match the rear guards with the front.
:O cheers :O
Edited by Sydneykid
I got mine custom for $70 :nyaanyaa:
I think I got a catalogue at work that has them in there from some Victorian Company that makes them and other car accessories. and they are in there for about $130 for a pair ($65 each) Might have to check that price again though..
yeh the trusty SK tramline setup can be hard to drive..
i better not drift this wkend on my 18 by 9/10 neg 17s
suspension might explode on impact with tarmac
:D Cheers :P
*shrug* you can believe whatever you want mate, but personally, i'm with SK on this one... its sheer physics... and basic (i.e. year 9 level) physics at that.
    • Yeah that's true, but idk. Only a 6 month lifespan seems a little short. Oh also, is there a preferred way to send images? Like any sites? I'm used to just being able to upload them lol
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
