i first met john years ago - mad inventor and almost impossible to pin down but what he does is first class. he made a trick cooling set up for my 440 cu in BB Chrysler but not with water jacket take-offs like i understand from Alex, the guy he works with, that they are doing now for the rb. i spoke to Alex recently and he mentioned they were going to do this soon.
some discussion of the issue in general is here:
http://www.skylinesaustralia.com/forums/in...8&hl=bennet
does what john /alex are doing seem similar to the jun set up discussed here?:
http://www.skylinesaustralia.com/forums/in...122687&st=0
i haven't seen their system, did you take pics etc? back to back testing would be great and it's the type of thing john would insist on, did you ask them for results?
on a seriouse note
the idea of removing the funny little coolant header/bleed log on a rb. mainly on a rb26
and replacing with direct waterlines is a VERY good idea. as this evans up the temp differance between the front and rear of the head
hmmm ok im building an rb25 atm and am going down this path ive also met mr bennet and alex through my uncle chris from beyond the limit motorsports[ very switched on people ]
and thanks for the links scooby intresting reading for i didnt entirely understand the whole theory behind this but obviously has to make a huge diff in reliability and general eficiency of the cooling system/motor package and also there oil system theorys sound just as good and would be worth while looking into aswell
don't get carried away with spending money on this mod too quickly, a large school of thought suggests that this is not worthwhile for RBs until the power gets really serious. they are not the boiling prone monsters that a lot of old V8s were (don't know enough about the new ones to comment). there is little doubt a similar system on an old V8 would seriously improve it dramatically, as i found, but make JB prove to you that either power, efficiency or driveability are improved before you spend money on this for an RB. did they talk $ at all?
cheers
Sprint car builders have been doing this for ages, I think Smokey Yunick started doing it back in the 60's + 70's. But as to why it's a "new" thing has got me buggered.
Haha and good call on the commando line, the line "Let off some steam Bennet" really is applicable to this... as that's the main purpose of the bleeders.
yes the japanese companies even have car specific kits for it. ARC make a very nice GTR kit and it's well under $400 and of course comes with all the bits to make it a bolt on process.
Richard, the ARC kits look different to whats in the pics from exvitermini ... they seem to be really just a swirl pot and external header tank setup.. rather than pulling water from 3 places along the block ..
still trying to et my head around this and look at ways it can be done with the rb25 head...
main issue i have as to a reason to use a thing like this is due to the front facing plenum im using not retaining the radiator bleeder from the TB water feed, so i cant bleed the system 100% currently
my other option is to try and include something like the justjap item like below
but that wont even out the water temps from front to rear of the block...
by the looks of the ARC kit, neither do they : - well the ones on nengun dont anyway
This doesnt seem to be a complex modification as the only parts needed from what I can see are:
Extra Outlet on radiator
Braided Lines and Fittings
Reservoir mounted on strut
it's not complex but the problem is the cost can add right up once you take fitting into account.
it's not really new but no one out here does it that much - the culture has generally been 'use a bigger radiator, take out the thermostat etc' because people can't see the boiling in the block and it's also hard to measure. they can see the radiator puking colant but steam pockets are hidden - that's why the good guys like Smokey are good, they know stuff. Chevy is just now releasing heads with coolant passages that have ports half way along.
exactly. there's kits and there's kits. the one on exvitermini, jun, etc are the whole enchilada. just getting a reservoir is not going to make much difference imho unless you needed to create a higher fill point for some reason. the water will cool as it comes to the front of the block anyway and the steam will condense if it travels. problem is large steam pockets occur at given points due to localised heat, hence the take offs you see with the jun type kits. the other issue of course is a good water pump. i reckon a good pump will solve most problems given that RBs have a high bleeder.
Edited by Scooby
